Brand New Mini Mono ESC Questions. 2013
  • czegard
    • Nov 2012
    • 151
    #31
    Mines are 3/4 inches wider than stock strim, and don't know how long they should be.....
    I will cut them tomorrow, to your same lenght, and then cut small pieces after the tests. Hope to do test this weekend.
    I am using aluminum 1mm thickness, alloy 3105, temper H26. Good alloy for forming.
    I will keep posting!
    Sent from my iPad using Tapatalk HD
    • czegard
      • Nov 2012
      • 151
      #32
      [ATTACH]94856[/ATTACH]
      • lenny
        • Sep 2010
        • 4294
        #33
        1 3/8" wide x 3/4" to 1" long tops for that hull.
        Just a little over kill on those big ones you made.
        ? ONLY IF THEY WORK
        • lenny
          • Sep 2010
          • 4294
          #34
          So where are the inside shots of the Mystic ?
          Originally posted by Garrett
          Inside of the mystic as requested.
          Sent from my C771 using Tapatalk 2
          ? ONLY IF THEY WORK
          • Garrett
            • Mar 2012
            • 126
            #35
            I added a secondary rudder, burnt my OEM ESC, so I installed the Sea king 180A, the additional rudder I used as the cooling for the ESC, and the other cools the motor. I installed a water outlet on the left side of the hull, opposing the right side. I've also added an auto bailer to each hull or sponson, I'm getting about 50 mph and 30 minute run times. Not at full throttle the whole time. Also I'm running twin 11.1v Lipo batteries, at 20C. The trailer is also from Trailcom, SSDunlimited.com
            • lenny
              • Sep 2010
              • 4294
              #36
              That is nice run time,
              The c rate I would go to 30 c at least for boats and the higher you go the more power you will have.
              Also the setup will run a lot cooler to.
              Ok on you cooling to the motor,
              You should have the in line at the lowest nipple so it fill the jacket to the top nipple and exits out,
              It will take more water to fill it that way be for it come out the nipple.
              Also will cool the can 25% more.
              ? ONLY IF THEY WORK
              • Billy Barnacle
                • Dec 2011
                • 66
                #37
                The trailer is custom from Trailcom. SSDUnlimited.com
                Garrett
                I found trailcom / SSDUnlimited.com on the net recently, how much $$ did they charge you for the trailer??
                • Garrett
                  • Mar 2012
                  • 126
                  #38
                  My mystic trailer was $225. My airboat trailer was $185, and the mini mono trailer was about $100. They've all been powder coated. And the Spartan trailer I bought for a friend was $225.
                  • czegard
                    • Nov 2012
                    • 151
                    #39
                    Garret,
                    Just finished my trims.
                    I will try test now.
                    Sent from my GT-N7000 using Tapatalk 2
                    • Garrett
                      • Mar 2012
                      • 126
                      #40
                      They look great. I was testing mine this evening and the motor mounts broke loose. Gotta re-epoxy the brackets down.
                      • Billy Barnacle
                        • Dec 2011
                        • 66
                        #41
                        Thank You for the info, the trailers I've found so far (pre-built) were in the $200~$250 range. So those price's are quite reasonable, especially considering they're built to order.
                        BB
