just bought one of these for my son for christmas and wanted to get a upgraded flex shaft does anyone know who sells one that is ready to go for this boat im gonna run a 35a seaking on stock motor for now but i need the cable
flex cable
Just unsolder the flex and get a piece of .047 Piano wire and put back in. did it to my daughters Mini.Modified Jae21, Stock Jae21, Cheetah, Ul-1, Shock Wave 26 V2 (Rescue Boat). -
I used a torch but should be able to do with solder ironModified Jae21, Stock Jae21, Cheetah, Ul-1, Shock Wave 26 V2 (Rescue Boat).Comment
I just heated up the shaft till the flex came out and then heated up the wire and shaft and but them back together.Modified Jae21, Stock Jae21, Cheetah, Ul-1, Shock Wave 26 V2 (Rescue Boat).Comment
I am working on a new 062 wire drive with new x432 prop and drive dog. I could mske new couplers but drilling out 47 to 62 is simple. Anyone interest? Getting a lot of emsils on this.Comment
Ok Jeff,
I just went to your site and ordered up your driveshaft setup. I had all the stuff from coupler to prop not for the octura 098 flexshaft but have been to busy to gut the boat (and I didn't want to). I already have my 3900 kv watercooled inrunner/outrunner (I don't remember its blue and from hobbyking) and a SeaKing 35a in place. All I had to do was enlarge the cowl opening to shoehorn in the motor, and then trim the motor mount to make the water cooling tube not kink. Up next is solder on a deans connector. Then install Jeff's 062 shaft. I have 3 octura props waiting Y531, X432, and X632. All in all its pretty plug and play should be good.
After this its some kind of 6s rig, Revolt 30 or Impulse 31 (or any other suggestion).
Sobie2Comment
No I haven't run it, the kit was not a quick plugin play as advertised. You had to drill out the driveshaft with a 1/8" drill bit and when I tried that the driveshaft spun out and the bit got stuck and 1/8 isn't big enough. So it's on hold till later. I even have a complete octura 098 shaft kit but heard this was an easy one... Nope
Sobie2Comment
