Lost prop shaft blues
I've lost several propshafts (along with the prop and propnuts thank you).
I noticed those are all sold seperately.
The wire either spins loose from between the setscrews and falls out, or the wire pinches off from overtightening the set screws.
I came up with a simple modification.
drill an angled hole in the side of the coupler, and bend the shaft wire to run out the side of the coupler.
This effectively "keys" the shaft. The set screws only have to be tight enough to keep it from pulling out in reverse.
the coupler has to be removed, and to do THAT, the drive shaft tube has to be shortened.
Best done with a dremel, being sure to protect the hull with something in case you slip.
I used wood shim tips.
then cut back the tube.
remove the coupler
use an automatic centerpunch to mark a spot roughly centered between the setscrews.
start a 1/16" hole straight down into the coupler, just enought to get a bite and then drill the hole through to the center at about a 45 degree angle. Drill TOWARD the propshaft end of the coupler (smaller hole).
Then drill out the propshaft end of the coupler, increasing the hole size to about 7/32".
This gives you room to work the wire into the key hole.
Then it's just re-assembly (don't forget the boot on the end of the propshaft sleeve), and use plenty of shaft grease.
Final step is bending the propshaft wire.
A radiused curve as shown will help work the wire into place.
With practice, a tighter angle bend will help reduce vibration.
Image is shown out of the boat for clarity and compared to a straight shaft.
Finished install should look like;
I hope this saves us ALL a bunch of money!!
remove the coupler
