Cooling
  • Junior5150
    • Jun 2008
    • 19
    Now to figure out a way to mount!
    • chirotray
      DocFowler
      • Jun 2008
      • 139
      Good luck, let everyone know how it works.
      Yes its fast, yes it will go far away, yes its expensive. No you cant try it.
      • Junior5150
        • Jun 2008
        • 19
        will do!
        • Junior5150
          • Jun 2008
          • 19
          Here is a video I made from saturday. I tried the brushless the next day but it made my batteries so hot i couldnt touch them so I converted back. I think the brushless needs a 3s pack not a 2s pack, ny suggestions?
          • Bigmax
            • 27
            It's not a 2S or 3S issue it's a C rating issue... and your pack doesn't have a high enough C rating for the brushless motor you're using. My Ammo 35-28-3900 and 2S 1250 mah 20C pack will get very warm / hot and that pack is good for 25amps.
            • Junior5150
              • Jun 2008
              • 19
              Thanks for the info....I will have to do research on the c rating and my particular motor/esc. Interesting info.
              • Manny
                • Jun 2008
                • 32
                Check out the cooling system on a mini rio here, scroll down to see pics.
                • Junior5150
                  • Jun 2008
                  • 19
                  #23
                  Here are some pics of the coil I just fabricated. Its a little tight but it fits. I used brass/copper (not sure) and soldered it together thinking the solder would give more area to help the heat move to the water....we'll see!
                  • Junior5150
                    • Jun 2008
                    • 19
                    #24
                    More......
                    • Diegoboy
                      • Mar 2007
                      • 7244
                      #25
                      Originally posted by Junior5150
                      Wonder if one of those silicone ones would work?
                      Here's my ammo 28-35-2700 with a silicone water jacket!
                      • Jon K
                        • Jul 2008
                        • 35
                        #26
                        That ammo is brushless? What other hardware do you have to support it?
                        • Diegoboy
                          • Mar 2007
                          • 7244
                          #27
                          Yes it's brushless...
                          Here's my HW
                          • Jon K
                            • Jul 2008
                            • 35
                            #28
                            Those are the custom made rudders? Does anyone make anything semi bolt on thats similar?
                            • Diegoboy
                              • Mar 2007
                              • 7244
                              #29
                              No. you're right, they are custom made. They are also direct bolt on replacements. No mods needed to install.
                              • Jon K
                                • Jul 2008
                                • 35
                                #30
                                Do you sell them? Does someone else?
