Twin 380 Brushless Mini-Rio !?!
  • FighterCat57
    "The" Fighter Cat
    • Apr 2010
    • 3480
    Can it be done?
    I should have two extra 380 2850Kv motors & 60a ESC's. Should be able to squeeze a 3000mah 3s lipo in it.
    But... Will it be too heavy? Will it still float?
    Is there enough room to work in the hull?
    The question remains... Can it be done? Should it be done. The answer is... Am I going to do it. =)
    ________
    PROFESSIONAL INDEMNITY INSURANCE ADVICE
  • Diegoboy
    • Mar 2007
    • 7244
    It shouldn't be done because there is no room.
    It shouldn't be done because it'll be too heavy.
    It shouldn't be done because there is no reason to make a mono with twins.
    It shouldn't be done because it's too much money to invest in a cheap ABS hull.
    I say go for it!
    Seriously, if you really insist on doing it, use 2 20mm motors instead of 24mm (380). You'd have better luck if you do it to a mini-v instead. (more room)
    • FighterCat57
      "The" Fighter Cat
      • Apr 2010
      • 3480
      Well... I have the mini rio already... We'll see how ambitious I am when I have the motors in hand...
      ________
      Jailbroken
      • forescott
        Hopelessly Addicted to RC
        • 2686
        Ben, are you looking for a place to put those venom motors???
        • FighterCat57
          "The" Fighter Cat
          • Apr 2010
          • 3480
          Perhaps... However sadly... I don't think they are going to fit in this hull.
          I might find a nice 18-24" cat though. With less load they might last.
          ________
          E70
