Run Time and Largest lipos that fit?
were these ran in parallel to get 9min runs?.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8s
Is your Low Voltage protector on your speed controller kicking in after 7.5 minutes?Grand River Marine Modellers
Yes, I'm pretty sure it did. I could tell the boat was slowing down so I took it in. I think that's what the manual refers to as the "stutter warning system". I have not changed the stock ESC programming and I run standard 4S.Comment
The manual does clearly agree with the partial throttle part. But I can't stay deep in the throttle due to my water conditions. I keep flipping it. I guess I picked the wrong hull for the lake I live on. :)
I have kept a close eye on temp (spektrum DX3S real time temp) and haven't had a problem... Yet!Comment
I thought I was operating within "normal" use - keep voltage over 2.9 per cell. Keep temperature under 130F. But I wont press my luck with hitting the Low Voltage Cutoff. It's just like driving my automobile - I don't need to actually hit the rev limiter just because I can. Thanks for the advice.Comment
yes it will make the batteries puff after time, try to get 2 good 3min runs in off a set of 3700's and it should still have a little left in the batteries. for fe it is good not to take out more than 80% of your batteries mah- they'l last longer and run betterComment
i usually run them till about 3.75 volts per cell- thats with no load on them(not running the boat) if they were under load they would probably be @ around 3.0-3.3 volts per cell. it takes a lot of power to push a prop thru water- its nothing like rolling on a bearing on the ground like in a rc carComment
