new lipos
  • scoota
    FE DOWN UNDER
    • Dec 2008
    • 409
    new lipos
    guys , these hyperion lipos are worth looking at , can be charged @ 5c good value & gobbs of power @ 35c ,oh you will get 4x more charges out of them compared to any other lipo on the market if looked after, lets hope they fit in my UL-1 when it gets here. cause i was reading the battery lenght has to be under 155mm & there 156mm not including the leads
    UL1- 1515 castle/neu / 240 swordfish
    SV27- with UL1 running gear
    33 Delta Force - 1521-1.5D/Neu/ 240 swordfish/4S2P
  • Shooter
    Team Mojo
    • Jun 2009
    • 2558
    These are working very well for me so far. I'm running the 5500mah packs. They are definitely longer than a standard pack and are snug (but not tight) between the motor rail and the hull. As long as you line up your wire leads on the inside (closest to the motor), you can avoid over-bending wires, etc.....
    • scoota
      FE DOWN UNDER
      • Dec 2008
      • 409
      What do the 5500 packs measure ?
      Cheers jason..
      • Bill-SOCAL
        • Nov 2007
        • 1404
        Originally posted by scoota
        charged @ 5c 12-15 minutes to recharge down at the lake
        That's a 6.5 amp hour pack. A 5C charge rate is 32.5 amps. Do you have a chrager than can charge at that rate??
        I can only do 10 amps with my Hyperion DUOs. Even the new one (DUO3) can only do 15 amps. So that is a 1.5C to 2.3C rate.You'll be amazed at how little time difference there is between those two rates.
        Don't get me started
        • scoota
          FE DOWN UNDER
          • Dec 2008
          • 409
          I guess it depends on how bigger lipo your trying to charge, a 5000 pack would charge @ 3c better than waiting for it to charge at 1c if you ask me !! & i wouldnt charge them at 5c if you want long life out of them , i was just stating they can be charged @ 5c without killing them!!!! So at the presant you could only charge a 3000 pack @ 5c with the DUO3 . but how long till somebody brings out a better charger ???
          • Eggy
            • Jun 2009
            • 152
            Or charge a 4000mah @ 5C with the Eos 0720i Net3, with one 20A port.
              • 8012
              ...can be charged @ 5c 12-15 minutes to recharge down at the lake....a 5000 pack would charge @ 3c better than waiting for it to charge at 1c if you ask me !!
              We'd ask you, but you clearly don't have a clue. No disrespect intended, but like Bill stated if you expect half the charging time when charging at twice the amps, you'll be saddly mistaken. I know that the difference between 1C and 2C isn't much at all, not worth buying all-new packs just so I'd have more run time at the pond.
              The problem here is the low charge rate of the charger's final peaking program; that portion of the charge is very long. Since it is so important not to exceed 4.2 volts per cell, I don't see this changing much until cell technology allows some leeway in acceptable maximum cell voltage. Otherwise I guess you could skip the peaking function and run with packs that aren't fully charged.....
              It will be interesting to see how these cells actually perform under load. It is very easy to print a label saying 35C or 40C discharge rate, but as we know too well many times there are not even close to the cells' real-world performance. With Hyperion's rep I'd assume these are close to real numbers - but I've been fooled before.
              • Shooter
                Team Mojo
                • Jun 2009
                • 2558
                I monitor the voltage of each cell during the charge and agree with Fluid completely. Most of the charge time is the very end where the cell sits at say "4.18V" for about 30 minutes or so....
                As for the length of the 5500's, they measure 6.25". Here is a photo of them in the UL-1. Got a great deal on these (I think I paid around $65 a pc). They fit perfectly, just have to make sure the leads are on the inside (closest to the motor) to prevent kinking, etc... Kinking kills copper wire!
                As for performance, I haven't had a chance to compare apples to apples with another boat running the same set-up, but can definitely say they're not dogs!
                • scoota
                  FE DOWN UNDER
                  • Dec 2008
                  • 409
                  clearly i have no clue fluid & only was stating the claims of hyperion, so shoot me for being wrong!!!!, but i will say with some testing on charging & balancing one 7.4 lipo at a time them & then hooking them up to 14.8 if you have a balancing Y harness made up you will find the 4 cells are not balanced every time when testing .so i charge the two 7.4 batt hooked up as a 14.8 v pair with a balancing Y harness to get true balancing between the 2 packs you run in your boat , unless you have a new hyperion charger with twin balancing ports then your problem is solved . i share this info because it will extend the life of your packs & better performance ... Oh if you do make a balancing Y harness the resistance of the harness has to be equal a must !!!!
                    • 9488
                    Good point man!
                    some people have run out to buy new batteries so they can charge them faster only to realize now they need a new and expensive charger to keep up..
                    • Bill-SOCAL
                      • Nov 2007
                      • 1404
                      And right now there are not too may chargers to choose from that can do much more than 15 to 20 amps.
                      For instance, the DUO3 can do 15 amps, but is still limited to 180 watts per side. So at 15 amps the biggest pack it can really do is a 3S. SO you could charge two 3S 3,000 packs at 5C, but you will not see the charge happen in 20% of the 1C time.
                      For a 5S pack you max out at about 8 amps on a DUO regardless of the model. So to do a 5S pack at 5C it would have to be 1600 mAh pack. A 5,000 mAh pack would charge at no better than 1.6C which really makes no real difference in the total charge time.
                      Bottom line for me is these high charge rate claims do not mean very much in the real world, but they sure do seem to sell packs.
                      • scoota
                        FE DOWN UNDER
                        • Dec 2008
                        • 409
                        Good point man!
                        if you do your reserch before you spent your money on new lipos you find that your 5-6 amp standard charger would not do the job, for me it was not the charge rate , but more the mah rating ,c rating, value for money & the testing of these cells i have seen, a friend set a new speed record on the weekend running these cells
                          • 9488
                          I agree..
                          • scoota
                            FE DOWN UNDER
                            • Dec 2008
                            • 409
                            i might of been wrong in stating these lipos charge in 15 minutes , but what cracks me me up is nobody has said how long they would take to charge @ 5c ,only that there is not much time difference between 1c & 2c ! so if anyone has charged some smaller packs at 5c it would be interesting to know the time they charged in ?
                              • 9488
                              Funny?
                              your the one who told us how fast you can charge your 5c batteries! 12-15mins
                              you did an edit Last edited by scoota; 07-29-2009 at 04:41 AM. on your original post...
