Using a new cap.. I use 25V 2200Uf.. remove about 1/8" of the insulation around the + and - power leads leading to the ESC. Do this as close to the ESC as you can. Grim
Kintec racing has the 1500uf capacitors. Please tell us where we can get the 2200uf capacitors. Can I solder two 1500uf capacitors tegether to get 3000uf and then solder to the power leads going to the ESC?
Yes, you can. I went to radio shack and got two 25v/1000uf caps, tied them in parallel, tie the longer leads(+) the the red(positive)side, then the shorter(-) to the black side.
