Fastest UL-1 Video
What are you guys doing to be able to produce upper 45+ mph passes? I've got a scratch built twin-wing Circus Circus boat (painted as the American Spirit) with a UL-1 motor/esc and have only pulled off 44.2 mph passes with an X645 prop (25C MaxAmps batteries). Tried the M440 next and only got 42 mph. What prop was Brian using when he hit 63-64 mph? Thanks for the help!Attached FilesComment
Here it is...MODIFIED Octura 2047, but be careful or you will pop a cap. It would be good idea to add extra capacitors before using large props (larger than 40mm).
Hey guys, I finally got my hands on a computer.
The UL-1 really suprised me. I put an M445 on it for it's first pass, I flew it off and tumbled through the traps at 45mph. So I had a rough baseline. Next pass was with an M645 and 3/16" deeper on the strut, 52mph with a good ride attitude but still too light on the sponsons. 3rd pass was with a modified 2047 and a 1/2" deep tape air dam in the tunnel, 59mph pedaling it through the lights. Final pass was the same prop and air dam but 3/32" deeper on the strut, 65.7mph with a high 64mph return run. Temps on the final 2 passes were: motor 114F, ESC 126F, battery 109F (it had cooled down).
Stock motor/esc/hull. I didn't even touch the sponson bottoms. Total mods from out of the box: remove turn fin and vertical fins, tape air dam, strut adjustment and a fairly trick octura 2047. I did run my Futaba FASST 2.4G radio.
Then I put the turnfin back on with a 38x55 grimracer prop and ran 41mph for 8 minutes in rough water. I LIKE IT!!!
After the SAW passesLast edited by detox; 06-21-2009, 11:57 AM.Comment
Yea lol. I really wanted to wait until my GPS arrived so I could find out... What if it was 60's lol wow!
Nah Im exspecting 52-55mph...Im almost sure...could be wrong, but Im hoping, cause she's screaming.
Iv done all my passes so far on an m445.. Id like to swap over to an x442 with 6s2p.
Then Id most likely:
A: Need Air brakes
B: Blow over before 65mph
C:It blows up in flames.
Haha.
I need and x445.. S&B Got one anybody???LMT
LehnerMotorenTechnik.comComment
Hey detox, would you mind posting the pictures of you UL-1 with the Neu setup.. isnt you run high 50's???....LMT
That was my video of the 59 mph pass, and I witnessed the other passes in the 65 mph zone. I drove that boat that day, held it in my hand, and it was only changed as Brian said. Know too that SAW times are an average course speed, usually the boat accelerates way faster than the average speed at the end of the course. I watched Jeorg M. do his 141 mph record in 2006, and trained observers estimated a 160 + speed coming out of the trap one one single pass. I KNOW I'll get flamed for this [ Douggie help me out hereThis is not me but I had saved the video on my computer. Listen at the end it was a 59mph pass.
http://www.youtube.com/watch?v=nzExyBl_nag
] but all this " what's the fastest it'll go" hysteria seems wasted on a RTR which handles reasonably well at a design speed in the mid forties but develops all sorts of spastic behavior at higher speeds.
Whatever !
Last edited by properchopper; 06-21-2009, 02:29 PM.2008 NAMBA P-Mono & P-Offshore Nat'l 2-Lap Record Holder; '15 P-Cat, P-Ltd Cat 2-Lap
'11 NAMBA [P-Ltd] : Mono, Offshore, OPC, Sport Hydro; '06 LSO, '12,'13,'14 P Ltd Cat /MonoComment
So the 59mph pass was straight from the box with a diffrent prop... What prop was this?...That was my video of the 59 mph pass, and I witnessed the other passes in the 65 mph zone. I drove that boat that day, held it in my hand, and it was only changed as Brian said. Know too that SAW times are an average course speed, usually the boat accelerates way faster than the average speed at the end of the course. I watched Jeorg M. do his 141 mph record in 2006, and trained observers estimated a 160 + speed coming out of the trap one one single pass. I KNOW I'll get flamed for this [ Douggie help me here
] but all this " what's the fastest it'll go" hysteria seems wasted on a RTR which handles reasonably well at a design speed in the mid forties but causes all sorts of spastic behavior at higher speeds.
Whatever !
59mph for a RTR boat is great...
LMT
I really don't recall, but I think Brian disclosed this somewhere in a post. It's really a moot issue; once Brian "tunes" a prop, It doesn't resemble anything us mere mortals can get our hands on, just so you know. As a matter of fact, I showed up at the NAMBA time trials yesterday ready to set the P-OPC tunnel record with my rather fast running VS-1/UL-1 tunnel, and there was Mr. Buass grinning at with me with his well prepared fleet. With essentially the same setup [other than prop], Brian was a good 6 mph faster than my VS-1, which unexpectedly developed all kinds of outdrive issues culminating in a terminal servo malfunction.
So the guy can create one badass prop is that it?....I really don't recall, but I think Brian disclosed this somewhere in a post. It's really a moot issue; once Brian "tunes" a prop, It doesn't resemble anything us mere mortals can get our hands on, just so you know. As a matter of fact, I showed up at the NAMBA time trials yesterday ready to set the P-OPC tunnel record with my rather fast running VS-1/UL-1 tunnel, and there was Mr. Buass grinning at with me with his well prepared fleet. With essentially the same setup [other than prop], Brian was a good 6 mph faster than my VS-1, which unexpectedly developed all kinds of outdrive issues culminating in a terminal servo malfunction.
So pretty much any Noob getting into the sport of RC boats can't buy the UL-1... swap to a Grim prop or nice Octura and run 59mph.
LMT
Nate, While I honestly can't fathom where you're going with this, please consider the following :
Brian's 59 & 65 mph passes were made through the SAW traps.
A 60 mph SAW pass takes approximately 3.75 seconds.
If the noob[sic] wants to make 3.75 second runs there are bolt-on Grim or Octura props that can make it happen.
There will, however, be some downsides to this
Well I have another short video, This is were Im at so far.
When I got to the lake and had everything ready...I started running the boat out to the middle of the lake and all the suddon I hear a thud..lol
I must have hit a damn turtle!!
Well it bent my Speedmaster just a bit, then chopped off the tips of my prop,
I was a bit mad but still got 2 passes in, I belive it has way more in her but the prop was a bummer...
I need an x445 then I think it will see 55mph...
Ill know tUESEDAY for shure when I pick up the GPS from the post office...
Here it is.. First pass I was on and off half throttle playin around, second pass was beautiful!!!
LMT
I could not have said it better TonyThat was my video of the 59 mph pass, and I witnessed the other passes in the 65 mph zone. I drove that boat that day, held it in my hand, and it was only changed as Brian said. Know too that SAW times are an average course speed, usually the boat accelerates way faster than the average speed at the end of the course. I watched Jeorg M. do his 141 mph record in 2006, and trained observers estimated a 160 + speed coming out of the trap one one single pass. I KNOW I'll get flamed for this [ Douggie help me out here
Whatever !
DouggieComment
