Guess how many runs I got before this happened...
  • LuckyDuc
    Team Ducati Racing
    • Dec 2008
    • 989
    Well... After 168 runs on my UL-1 (Over 250 miles) my flex cable broke. I should have checked the teflon tube before now, but alas I didn't.
    The cable broke inside the stuffing tube because the tubing wrapped itself around the cable like a screw.
    It wasn't due to a lack of greasing, as I greased the cable every 3 runs. It looks like the teflon tube wore thin from use and bound itself around the cable.
    For those of you approaching 100 runs, CHECK THAT TEFLON TUBE FOR WEAR.
  • rightturnonly
    • Jan 2009
    • 143
    Ouch!!!!!!!!!!!!!
    JOHN A. GROSS
    MILLBROOK, AL
    Crickety Crack Racing Team
    • bigpapa
      • Apr 2009
      • 2330
      boat ok
      • LuckyDuc
        Team Ducati Racing
        • Dec 2008
        • 989
        Seems to be. I'll inspect the stuffing tube better tomorrow.
        • Camman
          • Jan 2008
          • 77
          Re: teflon
          Sorry to hear that
          Tell you the truth
          I have over a dozen boats & none have teflon
          did it mess the boat up & stuffing tube ?
          • jingalls007
            • 1015
            take out that teflon duc, get yourself a .187 cable and you'll never have to worry about melted teflon. you'll free up some RPM's too.
            • bigpapa
              • Apr 2009
              • 2330
              good luck hope all is ok
              • LuckyDuc
                Team Ducati Racing
                • Dec 2008
                • 989
                Some of you are not using Teflon tubes at all?!?
                I wonder why they included it if they are not necessary and cause excess friction
                • Camman
                  • Jan 2008
                  • 77
                  teflon tube
                  If I ever got a boat with it in there I always have taken it out. Most of my boats built by myself
                  I am not sure why manufacturers use it other than to make sure not to have any possible chatter from metal to metal bouncing but if you use a good grease in it
                  you won't have any, or atleast I have never had any in mine nor did my Dad when I was just a kid
                  Perhaps others will know why they use it
                  • AndyKunz
                    • Sep 2008
                    • 1438
                    Skip the Teflon completely. Use brass tubing that's the right size for your cable/wire/shaft.
                    Andy
                    Spektrum Development Team
                    • Capt. Crash
                      • Jan 2009
                      • 301
                      Will the .187 cable fit the stock coupler, strut bearing, props, etc?
                      • longballlumber
                        • 3119
                        Crash,
                        If you switch to .187 cable, you will need a new coupler for the increased cable size. Everything else will be fine.
                        Mike
