2nd Wet w/38x55
  • Drag Boat Bob
    • Apr 2009
    • 304
    2nd Wet w/38x55
    Thinking that the 38x55 would be more flighty than the stock prop I placed the GPS up front between the batteries. The boat handled great but seemed a bit too glued. I moved the GPS to the back and she rode much better (46.5mph).
    When making a very wide turn (and stupidly trying to go around a wake) the boat shut down. Seems I went too far and lost signal (?).
    After retrieving her with the tug, which took a very long time, everything worked OK. I will try again tomorrow and keep her closer.
    Tell me that I am not the first person to do this... I sure have a lot to learn...
    • 9479
    Keep us posted..
    Odd your UL-1 just shut down ?
      • 9479
      What batteries are you using?
      • alvinsmith75
        • Jul 2008
        • 635
        Come to think of it mine has done that as well, but picked right back up. I was thinking ESC. Your radio didn't work at all afterwards?
        • Drag Boat Bob
          • Apr 2009
          • 304
          Actually no. However, when I got it back to shore I gave it a try and everything worked ???. I hope it wasn't the ESC. Previous temps were very low. Batteries still had mucho charge... so I am not really sure.
          I will see what tomorrow brings...
          • detox
            • Jun 2008
            • 2310
            If it is a radio distance problem try new batteries and keep the boat a little closer to shore .
            But if it is the esc or caps next time boat dies way out on pond try rearming the radio to esc just like you do on shore. An esc with a bad cap will rearm then you can drive it back to shore. If boat continues to die add more caps.
            • Drag Boat Bob
              • Apr 2009
              • 304
              MaxAmps 6500 mAh (2s)
              • Drag Boat Bob
                • Apr 2009
                • 304
                Thanks Detox, but this thing has only been in the water a few times. I did however run it down to the LVC on the first run. The second run seemed OK. All temps seemed low (ESC 96). Maybe tomorrow will bring something to light...
                BTW, I followed your lead and purchased a bunch of caps (rubycon), but I don't see anything visibly wrong yet.
                Also, currently I am on a big lake and not experienced at distance for rc.
                • detox
                  • Jun 2008
                  • 2310
                  Two extra capacitors are good insurance.
                  • Ub Hauled
                    • Aug 2007
                    • 3031
                    More then one person in this forum has had problems JUST like that and it turned out to be the ESC... it was faulty from factory... talk to the Hobby Services if the problems persists.
                    • Capt. Crash
                      • Jan 2009
                      • 301
                      Saturday...mine died about 1 second into the take off. It wouldn't rearm until I unplugged and reconnected the battery. That is the first time in many, many miles of use. Hope it isn't a sign of things to come.
                      • Drag Boat Bob
                        • Apr 2009
                        • 304
                        I did notice that this time when I plugged in the batteries the receiver continued to beep instead of a single one. A pull of the trigger produced the single beep I was looking for and everything seemed to work in the beginning. Not sure if this means anything.
                        More data today...
                        • Capt. Crash
                          • Jan 2009
                          • 301
                          More data today...
                          Dial in more throttle trim...it should fix it.
                          • LuckyDuc
                            Team Ducati Racing
                            • Dec 2008
                            • 989
                            I have run my boat out of range of few times. When it looses signal it is dead on the water. I had to wait for the wind to blow it closer before it re-armed the ESC. Weak Transmitter batteries will shorten the distance too, so check the voltage on them from time to time. I try to keep my boat at 100yds or less... preferably 75yds or less.
                            Keep up the testing!
                            • TCR
                              • May 2009
                              • 139
                              What is the safe distance of the 2.4Ghz system on the UL-1, I've had the same issues you guys are talking about?
                              Tom
