I wanted to run some larger 6 series props with a 120 controller, is 9xl too much?
Motor replacement for UL-1?
Tags: None
I was wondering the same thing...I also have the Fiago 9xl and a Hydra 120 esc. I do not know if the esc would live using 4s1p. It should easily work using 4s 2p 8400mah.
It seems to me that the UL-1 likes the lower 4 and 5 pitch props better.
..........Comment
you just posted this as i was responding to the other, so ya, the question remains- what may be a good upgraded motor for the UL-1?? hmmm..Comment
Grim suggested the ammo 2300 on the stock SV and never heard of any problems. The 9Xl can be prop up as well becaus it is a lower KV...very close to the SV motor. Remember as well...more poles are easier on the ESC. Ammo is 6 pole. When doing this just be sure and prop down and move up after some testing. Amps will remain lower until you begin proping it up. Might try anything around 2200 rpm and at least a 56mm motor but do not go over 2300.Comment
I think im going to get that ammo 2300, tunrigy 120, and the m440 you suggested. should be fun.Comment
NEU 1515/1Y and prepare to fly...
just as a footnote, this hull was not design with
huge speeds in mind, I think Grimm himself mentioned
40-45mph or around there somewhere. Once you start changing
motors to go faster and faster, it will be a loose canon... just watch
out for kids on the shoreline,
:::::::::::::::. It's NEVER fast enough! .:::::::::::::::Comment
Agreed! I wouldn't go any more then what's been suggested to me here. i like to push the envelope but not be unsafe.NEU 1515/1Y and prepare to fly...
Just keep in mind that the ammo 2300 has a shorter can (50mm), so it will most likely build alot more heat from the extra wattage your pumping through it at those rpms. The stock can is 56mm long. If you are going to up the kv/rpms you should look for a 56mm or longer can.Comment
I though the ammo ran more efficently then the stock AQ motor. from what i've read the ammo motor runs very cool, however, each application is different. and since this was the upgrade motor for the SV and has been tested I figured it may be a decent upgrade for the UL-1. Originally I intended an XL motor, maybe an 8XL or 9xl. I've looked at those Medusas but i don't know much about them. your going to get the 36-60-2200 correct? what water jacket will you use?Just keep in mind that the ammo 2300 has a shorter can (50mm), so it will most likely build alot more heat from the extra wattage your pumping through it at those rpms. The stock can is 56mm long. If you are going to up the kv/rpms you should look for a 56mm or longer can.Comment
I’m not familiar with the Ammo 2300, or it's use with the SV. Are they running similar sized props... i.e Grim L40x57 3 blade? Cool temps on the outside of the motor can trick people into thinking that a motor is running within it’s limits when it may not be.
I can’t speak to the medusa in this application, but I do run a few of them in my EDF jets. They handle huge watts and spin 45,000 – 50,000 rpms constantly without a hiccup. I'm sure that the Neu 1515 will rock too. A tad out of my price range though. I plan to measure the Medusa when it arrives, and test fit my after market UL-1 jacket on it. I'm sure it will fit just fine.Comment
im intrigued by the medusa motors, never heard of them until you mentioned them. when are you planning to stick that in your ul-1?Comment
