UL power plant
  • ice329
    • 792
    The problem is no one is answering this question. will the UL motor and ESC be a hotter choice then the SV plant in the TS2 with a outboard. Small water looking to be quick fast running the hull to the limit. SV set up ot Ul setup. Changing props or whatever. Anyway... I am just gonna put the SV plant back.
    • sailr
      • Nov 2007
      • 6927
      Joey, not many of us here with OB experience. Maybe another forum?
      Mini Cat Racing USA
      www.minicatracingusa.com
      • Darin Jordan
        • 8335
        I think we actually did... There isn't a real "answer" to this question. I think that the UL1 motor would work well within it's limits and with the right prop, and I think the SV27 would work well within it's limits and with the right prop. Which one works "better" is really going to depend. I don't think anyone has enough experience with them yet to know for sure, and, as sailr has eluded to, there are other factors involved...
        I can tell you that on a typical, well balanced 28-30" P-OPC tunnel, where you can really only fit in 4S1P (tough to fit 4S2P in these things), that the hotter UL1 motor and limited battery capacity is going to require a good setup to keep things within the limits. As I said before, the UL1 motor starts pulling some serious amps as the loads increase and the question becomes CAN you get enough prop on an SV27 motor to where it's below it's limits and has the pitch to achieve the same or better speeds before the UL1 maxes itself out and can't take anymore prop... It may be that by the time you get there, but SV27 prop is so big that the boat no longer handles... Then again, maybe not.
        I regularly run Prather 235 or Octura X646 props on my SV27 powered OPC, and it's fast down the straights, but corning becomes iffy... I finish races, but it's only through some careful work in the turns...
        We'll find out more this season, but I feel at this point like the two motors can compete with one-another with the right setups... I don't know that one will DEFINATELY be faster than the other in the end. It's going to come down to setup and application and how well you can drive...
        Originally posted by sailr
        You totally misunderstood my post! I'm surprised by your response. PROPS ARE CRITICAL but not the ENTIRE solution! If you're going for SAW's, that's one thing. If you want to win races, that's another entirely.
        I did not misunderstand... but I did assume all-else being equal... And I don't think it matters SAWS or Oval... racing is racing... But you can shapen and blue-print and tweak a hull and everything else as much as you want, once all that is correct, you'll still get the biggest improvement in both handling and speed by getting the prop right...
        All assuming you drive smartly and can finish heats, of course...
        Darin E. Jordan - Renton, WA
        • sailr
          • Nov 2007
          • 6927
          Darin, granted, the right prop is still the biggest factor. We're on the same page just speaking a different language! ;-)
          Mini Cat Racing USA
          • Rumdog
            • 6453
            I get waht you guys are sying about the comprimise between handling and top speed. with the ammo 2600, i was thinking just s.a.w. speed. i'm assuming i'll lose some torque with the highter kv rating, so i'll surely prop down a bit to start.
            • properchopper
              • 6968
              Joey, I hear where you're coming from and perhaps this might help. My stock TS-2 with the SV 27 powerplant and an X442 ran great. Won my class at WW IV with it. Sometimes afterward, I tried the Ammo 36-50 2300 with an X437. Fast, but didn't hold the turns well & set the SC on fire. I think the SV combo is best for your setup; Listen to Darin. He & his amigos trim the cav plate off & swing bigger props for acceleration & decent straightline speed. Also, FWIW I'm running the UL-1 motor & a CC80 in my 29" mono LSO rig with a very S&B P220 & It'll go 4 + minutes for LSO with OK temps and reasonable speed. [ LSO is more of an endurance race as opposed to oval.] Tried a M445 & temps were going up past the three minute mark [ and the torque/propwalk of the bigger prop screwed up the left-turning ability so I'm sticking with less speed but more reliability.
              • Flying Scotsman
                Fast Electric Adict!
                • Jun 2007
                • 5190
                Tony, on the button
                Douggie
                • Darin Jordan
                  • 8335
                  #23
                  This pretty much confirms what I suspect is going to be the case...
                  In my LSO setup, using the SV27 motor in a DarkHorse 26 Mono, I can pull a prather 230 or 235, or an X646 and still have safe temps... using the SV27 ESC as well... Granted... those props had some work done to them, but handling wasn't an issue... maybe it would be different on a Cat...
                  Tony, did you GPS any of those setups???
                  • properchopper
                    • 6968
                    #24
                    Nope. With the M445 it was pushing 40, but with the P220 I'm fairly sure it was somewhere around 36-38 mph. Even with propping down, I needed to put in a high torque servo to swing the cut-down .21 Speedmaster rudder for left turns.
                    Another thing as well, the boat, a Titan 29 which runs fairly aired out, needed the batteries way over to port to keep torque from leaning the boat over. When it was rigged for P-Mono with a 9XL, an X442 was just great, but a little too slow hooked to the UL-1 motor [ go figure]
                    • Darin Jordan
                      • 8335
                      #25
                      Interesting...
                      Now, by way of comparison, my 26" DH Mono, with an SV27 power system and 4S1P 5000mah Poly RCs, running a Prather 235, ran 43mph consistently, with temps hovering around 125 or so on the motor, and about the same on the ESC... Batteries were just warm... Cornered very well, and just flew down the straights... BUT... I had to tweak the hull some to get it to run that way, as these boats typically run light... A little more turn fin also helped to keep it planted in the turn. Props were tweaked to get rid of some of the lift, and free things up in the lower thrust portion of the prop (backcut, cupped, detounged, thinned, etc...)
                      Goes back to the "old saying"... it's all in the Setup!
                      NOW, I would NOT have been able to run that setup at Lake Minden, for instance... water had way too much mineral content and things would have had to been prop'd down a bit...
                      • detox
                        • Jun 2008
                        • 2318
                        #26
                        If I DID try running the SV motor/esc combo in the UL-1 hull...do you think a large 3 blade prop would handle better than a large 2 blade prop in the turns? What would be a good 3 blade prop to use that would help sponsons run a little wetter for best handling and fastest speed using the SV motor/esc?
                        • Flying Scotsman
                          • Jun 2007
                          • 5190
                          #27
                          Keith, I have not run my UL-! due to weather, but I will try a Y537/3, which is contrary to your question. It is just a prop I like...the proof will be in the pudding
                          Douggie
                          • detox
                            • Jun 2008
                            • 2318
                            #28
                            Thanks Douggie, I have lots of props, but little time to test.
                            BTW...I like your avatar.
