Got a UL-1...let's see it!
  • Rumdog
    • 6453
    #166
    Detox, that gear couldn't get more snug in there man! hopefully the esc holds up for ya, that thing sould really rip!
    • detox
      • Jun 2008
      • 2318
      #167
      Changed my mind. I will be using the NUE 1515 1y/s (2200kv) with the Grimracer L38/55 prop. I will have to be very careful not to burn the ESC...no off and on throttle. If it does burn I will use my Hydra 240.
      • nate
        • 1652
        #168
        It shouldn't burn up that Hydra120 with 5s and right prop...
        LMT
        LehnerMotorenTechnik.com
        • LuckyDuc
          Team Ducati Racing
          • Dec 2008
          • 989
          #169
          I couldn't get the L38x55 to handle well with my 2200kv motor. Good luck. I'll bet you like the L40x57 a lot better.
          • detox
            • Jun 2008
            • 2318
            #170
            OK...back from the pond. Wind was blowing and water was a little rough so I couldn't let her rip, but boat obviously faster. The most throttle I could give was about 3/4. I will try again in the morning on smoother water
            Hydra 120 esc temp...170 degrees
            NUE 1515 1Y .............131 degrees
            Two G3 4s lipo's..........98 degrees
              • 9488
              #171
              Can't wait for the update Detox!
              • detox
                • Jun 2008
                • 2318
                #172
                OK...back from the pond. No GPS, but I would say 60mph easily using the L38 x 55 prop and NUE 1515 1Y (2200kv). Weeds are starting to be a problem...rudder would hang weeds and boat would slow down noticably (around 45mph). Boat was very stable on glass smooth water, but once UL-1 hit a small wake it would get very loose (it flipped once). I will add lead tape to the outer sponsons to maybe help stabilize boat better. FUN FUN FUN
                ESC temp.....145degrees
                Motor............135
                G3 Lipos........101
                • nate
                  • 1652
                  #173
                  Detox!! Video Now!!
                  LMT
                  • detox
                    • Jun 2008
                    • 2318
                    #174
                    I will will have to get my wife or somebody to film video and then I will have to figure out youtube before I can post a video. Hopefully it will be soon.
                    When will you have the Phil Thomas hull ready?
                    • nate
                      • 1652
                      #175
                      Ugghh Im done working on that thing for now, I got bored of that boat quick, I may sell it to get a bit of money to fix the trans problems in my car. Bummerr lol.
                      Yea 60mph Ul-1, sweet, Is it stable at that speed or wanna blow over?
                      LMT
                      • detox
                        • Jun 2008
                        • 2318
                        #176
                        Very stable on smooth water with no sign of blowing over. More weight should help stabilize UL-1 in race water.
                        • jingalls007
                          • 1015
                          #177
                          bored?? did you even run it??
                          • nate
                            • 1652
                            #178
                            nope. still along ways from done man.
                            LMT
                            • detox
                              • Jun 2008
                              • 2318
                              #179
                              Edit
                              • detox
                                • Jun 2008
                                • 2318
                                #180
                                I think if I modified the sponsons of UL-1 by using less AOA it WILL handle rough race water better. This will take major surgery
