UL-1 first observations
  • Jeff Wohlt
    • Jan 2008
    • 2716
    #31
    I use my kids little z boat or whatever they call it. Even has a guard on the front for pushing. The hole thing was $79. I also have the walmart 2 person blow up raft I keep in the truck $19
    If that does not work I send out the yellow Lab...I just hate the teeth marks in the hull she puts in it. :)
    www.rcraceboat.com
    jwohlt5362@yahoo.com
    • killjoy781
      • Jan 2009
      • 43
      #32
      lol no kidding thats awesome....well, i just dont want to get in the lake, ill have to find me a work boat under $40.00
      • Flying Scotsman
        Fast Electric Adict!
        • Jun 2007
        • 5190
        #33
        Killjoy, as my pm stated Vac- U- Boat
        • Doug Smock
          Moderator
          • 5264
          #34
          http://www.vac-u-boat.com/
          Yep, and ask Phil for the four blade prop.
          Doug
          MODEL BOAT RACER
          IMPBA President
          IMPBA 19887L CD
          NAMBA 1169
          • Capt. Crash
            • Jan 2009
            • 301
            #35
            Aquacraft makes a great RTR tug that with a few mods can be made to be quite powerful and useful. It's bigger than the vac-u-tug but not too big to get in the car and carry around. I use mine to set and retrieve the marks and do rescue duty. It does it all...from fast boats, to planes, to snagging and dragging sailboats and even rescuing little girls balls.
            • alvinsmith75
              • Jul 2008
              • 635
              #36
              That just doesn't sound right.
              "little girls balls"
              • Capt. Crash
                • Jan 2009
                • 301
                #37
                Yea...just think what would be said if I went with little boys instead...
                • Flying Scotsman
                  • Jun 2007
                  • 5190
                  #38
                  I will be painting the hull cover as I previously mentioned. Those folks over in China must have strong wrists and hands.
                  The exhaust manifolds were stripped and glue was applied to correct the problem. All fasteners are over tightened except at the motor mount? Which was loose. Removing the flex connector took a lot of force.
                  Douggie
                  • Capt. Crash
                    • Jan 2009
                    • 301
                    #39
                    Douggie
                    One of my manifolds were cracked from over torque and the motor housing to mount bolts were loose...be careful with them...they have very fine threads and strip out the housing threads fairly easy if you over tighten. My drive cable connector was also extremely tight as was the set screw.
                    • Darin Jordan
                      • 8332
                      #40
                      That's all interesting... Everything on mine came apart very easily...
                      Darin E. Jordan - Renton, WA
                      • Jeff Wohlt
                        • Jan 2008
                        • 2716
                        #41
                        Guys, those issues are what QC is all about.. This is common when dealing with China.
                        www.rcraceboat.com
                        • sailr
                          • Nov 2007
                          • 6924
                          #42
                          Grim,
                          My UL-1 is on order and should arrive in the next couple of days. Obviously the first thing I will check is the water jacket. Is AQ doing anything to replace the ones that leak with ones that don't? Just curious. Hate to have to go spend $15-20 for an aftermarket one that works.
                          Originally posted by Grimracer
                          We are just about done with the work on this.. hang tight..
                          I know.. boring blaha blaha blaha..just want it to work.. ME TOO!... none of this comes easy.. sorry and thanks for haning with us on this...
                          Grim
                          Mini Cat Racing USA
                          www.minicatracingusa.com
                          • Flying Scotsman
                            • Jun 2007
                            • 5190
                            #43
                            In my humble oppinion buy a replacement water jacket.
                            Douggie
                            • Grimracer
                              • Nov 2008
                              • 656
                              #44
                              Originally posted by sailr
                              Grim,
                              Dude.. honsitly i dont know.. but.. I will let you know when i know more..
                              I do know this.. when the time comes call Hobby Services and i will see to it that you get the updated parts.
                              Fear not the water jacket!...
                              Grim
                              • sailr
                                • Nov 2007
                                • 6924
                                #45
                                Thanks Mike. You da man!
                                Grim
                                Mini Cat Racing USA
