I run two 2S Flightpower 25C 5000's. Great setup. I don't think Steven (OSE) sells lipos. Right now, Towerhobbies is selling the Flightpowers at dealer cost! (I know, I'm a dealer and getting hosed over by Tower!) There is a new series of Flightpower lipos coming out so I guess they're selling off the original series. These are absolutely incredibly good lipos! You can't go wrong at the current prices at Tower. I believe the 2S 25C 5000's are going for $89.99. Normally $119.99! Get 'em while they got 'em. You won't get any cheaper for a quality lipo. Sure, you can get the Zippy's from Hobby City but they ARE NOT as good a battery and with shipping won't be that cheap... AND if you have a problem, you gotta send 'em back to China.... etc. etc. etc.
Darin's UL1 Race Prep
This is a sticky topic.
For what its worth, I got very frustrated spraying the new gen Krylon over prepared gelcoat and started using Testors Enamel and Model Masters High Gloss Clearcoat with very good results, Still have to let it marinate ( for lack of a better word) based on the instructions. Clearly, for abs or whatever the manufactures call plastic these days, Fusion is still a great product.Boats don't win races, drivers do.Comment
Oh, I thought it was the Tamiya paint you liked. I bought one of those tiny little million dollar spray cans and didn't like it worth a hoot! ;-) Since the hatch is abs plastic, I thought maybe the Krylon would work good. The UL-1 is painted, not gelcoat. Might wanta think of that.
For what its worth, I got very frustrated spraying the new gen Krylon over prepared gelcoat and started using Testors Enamel and Model Masters High Gloss Clearcoat with very good results, Still have to let it marinate ( for lack of a better word) based on the instructions. Clearly, for abs or whatever the manufactures call plastic these days, Fusion is still a great product.Mini Cat Racing USA
Mike, go easy when you clearcoat the decals I made for you. Too heavy and it will run the colors in the decal. Shoulda told ya that earlier!Mini Cat Racing USA
Will the Model Masters clear work over the Krylon?
Oh, I thought it was the Tamiya paint you liked. I bought one of those tiny little million dollar spray cans and didn't like it worth a hoot! ;-) Since the hatch is abs plastic, I thought maybe the Krylon would work good. The UL-1 is painted, not gelcoat. Might wanta think of that.Mini Cat Racing USA
Tamiya make different paints for different surfaces. The TS series is what would be used for most of our applications, a synthetic lacquer. Yes, they are expensive but are of a very high quality. They have a specific paint for Lexan materials.
The TS series is great because you can apply other paint types over the painted surface. Plus, no need for a clear coat which makes it easy to fix if you damage the paint suface.
http://www.tamiyausa.com/product/cat...?main-id=60|80
DouggieComment
Yep, gelcoat should not be harmed but any spray paint. I thoought these were gelcoat but sounds more like painted. Is this true?
Darin, fantasic paint scheem! It is very sharp man. Glad your boats don't run as good as they look! :)Comment
Thanks Jeff... I think it's paint... After the initial debocal with the white, I stripped it off completely, using Citri-strip, and it even took the red paint off... was a mess.
But, now, it's back in white, has the clearcoat on, and is mostly reassembled. I'm just waiting to get a water jacket for the motor.
Will be interested to see how it performs... Hopefully at least as good as it looks...Darin E. Jordan - Renton, WA
"Self-proclaimed skill-less leader in the hobby."Comment
Darin, I had to do the same procedure on a painted hull and it was a mess. Every other fix I tried without removing the paint just compounding the problems.
I trust that all goes well with the next painting procedure.
The original UL-1 suface is painted fireglass
DouggieComment
Here is my advice to anyone wishing to customize the paint on one of these... buy a color you like, and add lots of decals/graphics...
Much simpler!
It remains to be seen if my paint is gonna hold up to tape! All I painted was the hatch and cowl. I'm in the same boat as you...waiting for a water jacket. I gave up on the POS one that comes on the boat. Also had to do your major surgery on the right sponson where the fin bolts on. Mine came with the sponson pretty badly split open already. Just finished that job. I'm going to use the foam you suggested (it just arrived today) and pour it in several places in the boat. I just don't like how flimsy the hull is. Now I'm trying to find the little 1 oz medicine cups to measure that stuff. No luck at Walgreens!
Mini Cat Racing USA
