I am wanting to make an air dam that is a little more permant than hatch tape. I would like any suggestions. This is what I have in mind....I am thinking of using aileron material you can get from a hobby shop for a r/c plane. Basically it is triangle shaped balsa with a leading edge thicker than the trailing edge. I am considering doing it like the recovery pand on the Top Speed II. Just cut the dam to length, coat and it with epoxy to waterproof and attach it with double stick tape. Does this sound like a good idea? Would the front end of the air dam be the flat side or the tapered side? How thick should it be?
Thanks, Alvin
Thanks, Alvin
