Best motor for a UL-1
  • stelerzman
    • Jul 2013
    • 380
    What is the best motor to replace the stock 2030kv motor in a UL-. I have a feeling the motor I have is about to go, after every run it has that hot smell. I just went through burning up my stock esc and that could be it, but I'm not possitive. I now have a 90 hobbyking esc in. Any advice would be great. Thanks guys.
  • tlandauer
    • 5660
    How old is your motor? The AC 2030 motor is a great power plant (also considering the price point) but I understand some recent productions are riddled with issues of burning up and do a search you will see what people are saying. I had one I bought 2 years ago and it's been bullet proof so far. I use that one on my MinicatUSA Samurai, it is a sub drive prop. My recent purchase of a new one which I used in my BBY Zephyr, it is too soon to tell.
    What the discussion essentially boils down to is that the manufacturer might have changed the way they make their coil by using different lacquer.
    • Heaving Earth
      Banned
      • Jun 2012
      • 1877
      would be sad if that were true. such great little motors
      • Chilli
        • Jan 2008
        • 3067
        IMO the UL1 motor is the motor motor for that hull. It can handle bigger power but sooner or later the hull will probably fail. What prop were you running on it??
        Mike Chirillo
        www.capitolrcmodelboats.com
        • lenny
          • Sep 2010
          • 4296
          Hey,
          What temps are you getting off of the motor and setup after a full run ?
          Also what prop are you using and is the boat riding on plane for the whole run ?
          If it is still plowing the water like in the video to try and get on plane,
          Than yes you are going to have the hot smell after a run.
          And you will end up smoking any motor and esc you put in it,
          If the boat is not setup right and running on plane it is going make more heat.
          ? ONLY IF THEY WORK
          • stelerzman
            • Jul 2013
            • 380
            Stock......
            Originally posted by lenny
            Hey,
            Still running the stock prop and the temps are, batt-110*, stock esc-120* and the motor was 135*. These are the last #'s I was able to record. The following video link is with the HK 90amp esc and the stock motor and 2, 2cell turnigy 5200mah,30/40c batteries. It's a very short run because the boat was making a weird noise and I didn't want to risk damaging anything. Any way, here is the link.
            • JimClark
              • 5902
              ever do any maintenance on the motor? Id look at the bearings
              Billy Graham
              • stelerzman
                • Jul 2013
                • 380
                Great point, I'll be sure to check them out. Just an fyi I've lubed the besrimgs after each run.
                • JimClark
                  • 5902
                  also any friction in your flex or mis alignment?
                  Billy Graham
                  • lenny
                    • Sep 2010
                    • 4296
                    I still check temps there and everywhere else in the setup,
                    Just to know it is all doing good and running smooth.
                    The oil he is adding to the motor could be the hot smell of it heating up and burning.
                    ? ONLY IF THEY WORK
                    • stelerzman
                      • Jul 2013
                      • 380
                      I always re grease the flex cable before each run and clean it afterwards. Also, as I mentioned before, I always lube the bearings after each run. I'm not sure how old the boat and motor is because I purchased it used. Everything appears to be in propper working order when it comes to the drive line.
                      I do have another question, could the smell be from the esc when it went up in smoke? If that is possible maybe the motor is fine. Is there a way to clean out the motor to eleminate the smell or should the smell do away after time?
                      Last question, does anyone out there make 6 pole motors for these types of boats or is Aquacraft the only one? I really like the power it has and would like to continue running it.
                      Thanks to everyone that has posted info for me and others to learn from.
                      • tlandauer
                        • 5660
                        There is always THAT smell after an ESC burns, use denatured alcohol to clean, it will take away some of it. I personally don't think the oil in the BL motor would give you the smell unless the motor is extremely hot, by then the motor is already not worth a *****. BL motors do not give that comm. oil smell like those on brushed motors.
                        I have a Miss Elam with a Proboat 6-pole 1800kv motor. It's the highest kv they sell at the moment under the "Dynamite" label.
                        BTW, I forgot to mention that I have three F1 Out Board Tunnels , they all use the AC motors, out of the three one is equipped with an 1800kv motor, as I said, I love them and so far they are reliable.
                        • stelerzman
                          • Jul 2013
                          • 380
                          Thank you tlandauer for the insight. I'm defiantly going through the learning stage with these fast azz boats. Your info is much appreciated.
