ESC or motor?
  • buckt1
    • Dec 2010
    • 13
    ESC or motor?
    Hey guys
    my ul1 has been stored for 9 months (canada) bought 2 new lipos and tried to get her out. after I plug in the batteries I get the one beep and then squeeze the trigger but no 3 beeps or response from motor . the rudder circuit will \respond and if I switch at reciever I can make rudder respond by throttle so this should verify reciever.. some times when I plug in batteries it will beep 1 every couple of seconds and stops when I hold trigger. The esc end caps show no swelling but I dont know what else it can be other than esc as motor turns by hand. I am still fairly new to this so any help is great as parts up here take for ever and I would like a few runs on these new batteries, if it matters the new batteries are hard case venom 5000 50c
  • stelerzman
    • Jul 2013
    • 380
    What voltage does the batteries give you?
    • buckt1
      • Dec 2010
      • 13
      never actually checked , just trusted charger when it said full
      • Heaving Earth
        Banned
        • Jun 2012
        • 1877
        Make sure your throttle channel is set to reverse, then play with your trim till it calibrates
        • Doby
          KANADA RULES!
          • 7277
          yup
          Grand River Marine Modellers
          • bdp1174
            • 134
            I agree your trim probably is not correct try around 2 o'clock and reverse on throttle channel as the others have suggested and add a lil more trim to see if it arms.
            • buckt1
              • Dec 2010
              • 13
              I think I did switch things around but will try again, I do appreciate the help. I took the ESC to a shop and a kid tried it in a car , same thing, steering but no throttle but he wasn't the sharpest knife in the drawer so I will try what was suggested here than bite the bullit
              • buckt1
                • Dec 2010
                • 13
                you guys were right on the money! don't know how things changed but did what was suggested and it works.
                Thank you very much guys
