what is best heat racing prop for ul1
  • ww29
    • Feb 2010
    • 86
    what is best heat racing prop for the ul1
  • Heaving Earth
    Banned
    • Jun 2012
    • 1877
    I dunno about heat racing but the best prop I found is th L40/57/3
    • Chilli
      • Jan 2008
      • 3067
      Grim 42x55 is a good basic heat racing prop for a P-Lim Sport Hydro. I run a barr cut 442 on my Insane. A 445 is way too much on our water for the Insane though the UL1 is smaller and lighter. I would still be VERY careful if I tried it.
      You running a UL1 for the season?? You should ask Charles if he could add a B / P-Lim Sport Hydro class for the Greenbrier race. I already asked him to do Gas Rigger.
      FYI- Ft Ritchie race date moved up to September 21-22. The October date was the same weekend as Fall Nats....and my anniversary.
      Mike Chirillo
      www.capitolrcmodelboats.com
      • ww29
        • Feb 2010
        • 86
        thanks chilli hope charles adds the b/p limited sport hydro. i just going run the ul1 for couple races. till i get the fe30
        • Chilli
          • Jan 2008
          • 3067
          Thats what I figured. Plus you can move all the electrics over to the FE30 when you get one. It's a no brainer. The UL1 hull handles pretty well but can be a little fragile for heat racing so stay away from me. LOL
          A few suggestions. Replace the Deans and Aquacraft 4mm bullets with high quality bullets. The Aquacraft 4mm's are cheaply made and can fail. The Deans can get hot while heat racing. We're pushing much more than 60 amps through them. Go with 5.5mm bullets on the battery and good quality 4mm or 5.5's on the motor..... or you can solder the motor wires to the esc. Also with the Aquacraft speed controller you will probably have to play with your neutral trim on your transmitter when you first fire everything up to get the esc to initialize.
          Mike Chirillo
          • ww29
            • Feb 2010
            • 86
            what bullets should i use. i putting traxxes plus on the esc all my offroad battery's have traxxes plugs. what is the battery mah limit
            • ray schrauwen
              • 9438
              That depends. Some people have enough $$ to melt a UL-1 motor every race with some hefty props. Use 5.5mm bullet plugs all around.
              Nortavlag Bulc
              • Chilli
                • Jan 2008
                • 3067
                We try to discourge disposable motors in D12. LOL
                I'm for OSE 5.5's all the way around also. No mAh limit on packs. Most of us run 45C 5000's. Everything stays cool and plenty of juice to finish a race plus a little extra.
                Mike Chirillo
                • ray schrauwen
                  • 9438
                  You notice that there are lots of $50 UL-1 motors in Sept. - October every year...
                  Isn't the 42x55 Grimm also a nice prop? Thats what I want to try on my PTSS when things melt.
                  Nortavlag Bulc
                  • Chilli
                    • Jan 2008
                    • 3067
                    That whisp of oderless white smoke when untaping is the tell tale sign a UL1 motor isnt going to last a season.
                    I mentioned the 42x55 at the very beginning of post #3. It's A great bread and butter prop for P-Lim Sport Hydro and Tunnel. Even a detounged 442 was a little too much in the water I run in. I got Mr. Sholund to put a little bar cut in mine to get the temps down. I would guess the 42x55 has a little more lift. I need to do a little more testing with it.
                    Mike Chirillo
                    • Doug Smock
                      Moderator
                      • 5264
                      Ray, that's all due to the wires chafing at the end bell.
                      MODEL BOAT RACER
                      IMPBA President
                      IMPBA 19887L CD
                      NAMBA 1169
                      • ww29
                        • Feb 2010
                        • 86
                        chilli i have 65-130 nano tech 6600 packs are they legal?
                        • egneg
                          • 4664
                          Yes ... voltage is the only limitation.
                          IMPBA 20481S D-12
                          • ww29
                            • Feb 2010
                            • 86
                            thanks
                            • Chilli
                              • Jan 2008
                              • 3067
                              What Chuck Said. Any mAh and C rating is okay. but you'll be carrying allot of extra weight with 6600's. Then again the UL1 is most likely allot lighter than my FE30.
                              Chuck, you used to race a UL1 with the Old Dominion club. What prop did you like??
                              Mike Chirillo
