Feigao motors
  • G-UNIT
    • 949
    Feigao motors
    My LHS has a large assortment of feigao motors, what motor would be good for the UL-1 if I choose to go that route?
    • 7990
    A 7XL or 8XL would be a good choice, depending on the cells you are using and the speed/run time you want. If it does not fit (too long) try an 11L or 12L. The lower turn motors are pretty hot and would require good cells and a different ESC.
    • G-UNIT
      • 949
      Thinking 5s-6s. upgraded esc was looking at the HK120 from hobby king, run times about 4 min, speeds, high 50s-60s with the right prop, propably my modded m447 cut down to ABOUT 46mm with spooning and cupping.
      5000mah 30c
        • 7990
        Why didn't you say so in your first post instead of making me guess? Those motors are not suitable for 5S or 6S, and frankly neither is the UL-1; but if you want to try...
        5S: 9XL or 10XL again depends on your cell quality.
        6S: 12XL
        • G-UNIT
          • 949
          I have run the stock motor and ecs on 5s with a speed of 56.8 but just a matter of time before I burn some thing up
          and just trying to get some suggestions.
          sorry to waste your time and thank you for your response.
