Hello Im a car guy trying to get into the boat world. I have a castle 2200kv 1/8th scale motor just sitting around can that drop right into a ul-1. Does water jacket fit and or is there anything else i need to know? Should I expect performance gains or should i just leave well enough alone and stick with stock. thxs abunch
2200kv drop in?
The CC/Neu 1515/2200kv motor is a decent choice. A bunch are using that motor with great success. You dont need a motor that big but if you got it already then why not. It will bolt right up to the stock motor mount. The stock UL-1 cooling can will not work on that motor. You would need to buy one from OSE or similar if you wanted a cooling jacket. But you dont really need one. Even using a big prop, like a 445 or even a 545 it wont over heat that motor for the size batteries you can stuff in the hull. So dont feel like you have to water cool it.
I run a Leopard 4074/2150 motor (close equivalent to the better CC/Neu 1515) on 4S with no heat issues. I only cool the esc just to not waste available cooling for my T180 esc.
What I would recommend is to add a tapered block glued down under the motor to the floor pan and wire tie or something similar. The thin stock motor mount does flex using the, longer, heavier, more powerfull motor and if you add a lower wedge block with a wire tie on the end of the motor the flex is greatly reduced. Dont know if that makes sense but it keeps the flex shaft from being pulled and pushed about while the stock mount bends.
I once tried the 1515 1y 2200kv motor in my UL-1. I used the smaller m440 prop to keep boat under control. Using the m445 hull was wicked fast and loose (easy to flip). No motor support is needed. Hydra 120 did not last very long eather.Attached FilesComment
This might be a stuip question what about the mamba max esc that i bought in the combo with the motor. I could waterproof it and it is fan cooled or is that a no go. Its just I have one of those sitting around to. Is that idea a no go? and why if no.. please, thxs again everyone. BTW I have another thread goin with prop issues just trying to go a little faster and the prop isnt working out. Its my fault im sure ,dont know crap about boats but im trying to learn so I appreciate all and any helpComment
Whats the amp rating on the Mamba ESC? A boat getting pushed through the water has allot more drag than a truck rolling on a level surface or even slightly up hill. Thus boats put much more load on a motor. Propped reasonably your motor is probably pulling in the area of 120 amps. Even more when accelerating or in a sharp turn. You'll need at least a 180 amp controller to be safe.Mike Chirillo
www.capitolrcmodelboats.com
The Mamba Monster may work with that motor and 4s. The small m440 will work nicely:
I once used that esc with a nue 1515 .5y (1500kv) and 6s in my Phil Thomas SS21.Comment
Detox i dont understand you burnt the hydra with same amp rating but you had no problems with mamba setup on 6cells. So will I be safe running on 4. For now I think im just goin to run the stock prop Im having issues with the 40/57 i bought was told thats not a good choice since that was the 1st prop i ever sharpened and balanced. Is the m440 something easier to work with? Can i even run the stock nylon prop safely? thxs abunchComment
You will break the blades off the stock prop , try one of these http://www.offshoreelectrics.com/pro...od=grp-2317.45 cheep & they are balanced , here is a pic of my setup 1515 1y cc/neu & a 240 swordfish esc , runs cool & speeds in the high 50s , i have just cut up some pool noodle to wedge under the motor for the extra weight on the mount ..Attached FilesLast edited by scoota; 05-14-2011, 05:13 AM.UL1- 1515 castle/neu / 240 swordfish
SV27- with UL1 running gear
33 Delta Force - 1521-1.5D/Neu/ 240 swordfish/4S2PComment
