UL-1 cutting off issues?
  • lussorocuztoms
    • May 2010
    • 53
    ok guys, this is my second ul-1 first had a runaway destroying the boat last year, decided to pick up another one. received it monday, had to wait till today to run since wind has been crazy here lately, anyhow tossed her in the water hit throttle, she sub-d a little at first no biggy ( that can be fixed later) ran about 2 laps around my pond and she shuts off? i row out pick her up, check packs, recharge toss again same thing just shutting off after about 30 seconds? take out the packs that came with the boat(used) throw in some 5200mah 2s 40c packs, toss her out again.... same frikin thing!? I have no throttle, after about 3- 4 min by time i row out to get the boat she will have throttle again then run for a few seconds and stop. i checked motor temps mid 80s, esc temps mid 70s, packs were around 8.30volts, so im thinking either esc is tatered or the tactic radio and rx is trashed? any ideas? I dont know if should throw in a spektrum rx and see what happens, run a rx pack and eliminate the stock bec? or just return the boat and buy NEW? Im frustrated this is the second boat now ive had problems with please help.
  • Alexgar
    • Aug 2009
    • 3534
    Try adjusting the th trim I notice I was hitting lvc under load and esc would not rearm because I had a bit of positive th trim it was with a sf120 but had me stumped today to and only ran it twice
    • Doby
      KANADA RULES!
      • 7280
      One word....Capacitor. I assume that you have the 60 amp UL-1 controller...add a new cap and you should be good to go.
      Grand River Marine Modellers
      • pescador
        • May 2009
        • 499
        and double check for good solder joints on the motor bullets.
        Namba District 16
        • Grimracer
          • Nov 2008
          • 662
          solder joints for sure.. a bad cap would only get you about 10'
          Grim
          • CHUD
            • 497
            Same thing happend too meeee!Only after getting a hole other setup did I find out it was the cap,I thought it was the proboat controller ,so I got a used tactic 2.4 ,But when I tryed it samething, only then I was told to change the cap.I hope this help's you out,GOOD LUCK
            • lussorocuztoms
              • May 2010
              • 53
              ok, so how do i change the cap on the esc? and what cap do i buy? can someone show me how to do this or a link please thanks
              • Doby
                KANADA RULES!
                • 7280
                Theres a great feature on this forum called a search feature;
                http://forums.offshoreelectrics.com/...ight=capacitor
                • lussorocuztoms
                  • May 2010
                  • 53
                  haha your funny doby! yes i know about the search but sometimes it doesnt always give you what your looking for , anyhow i do thank you for the link partner.
                  • CHUD
                    • 497
                    Here's a pic of how my brother HJ solder mine together 'and I picked up some Liquid tape from wallmart ,Just strip the wire and solder it to each other,Ose has the cap's,goodluck one to neg and one to pos
                    • lussorocuztoms
                      • May 2010
                      • 53
                      thanks guys your awsome, i will give it a try and see what happens!! im really hoping it works!( obviously it does if you guys have done this before)
                      • G.Rose
                        • Apr 2010
                        • 643
                        Before you do anything do what Grim said. I have had two motors do what yours does. All it was was the wires melted the solder on the motor side the connecting bullet. you can't see it until you pull the Esc apart from the motor because of the outer covering of the wires.
                        • CHUD
                          • 497
                          Yes I would also look at what is in front of me too
                          • detox
                            • Jun 2008
                            • 2318
                            Grim
                            When is Aquacraft going to beef up those motor connectors?
                            • G.Rose
                              • Apr 2010
                              • 643
                              That is why I use 5.5 conecters on everything. After soldering I put TWO layers of shrink tubing around the wire and bullet connecter
