I moved the steering rod up 2 spots on the servo horn to give more steering throw in doing so I broke the plastic piece/rod holder thing ... I put a c clip and body clip it seems it won't go anywhere will it be ok or is there an easier fix. I really don't wanna spend $18 for a piece of plastic...
Servo linkage help
Ca glue works good, fast & med or epoxy. -
I would not glue the rod end plastic, it will only fail and you could crash the boat. Rod end keepers are available cheap at any LHS that sells planes. You may be able to find a wheel collar to fit over the hooked end to keep it on the servo arm.
What about Middletown Hobbies? They have airplane stuff...they should have them....Comment
yup!Comment
? ONLY IF THEY WORK
