will the seaking 60amp ESC work with the stock UL-1 motor ?
ESC question
hi guys!
do you thinks the 5800mah turnigy 30c was good for the stock esc with 5,5mm connectors! because the burst current is 72A on the stock esc and when i calculate 5,8x30=174!!Comment
It's fine. The only thing that matters on the battery beside the correct voltage is that the continuous current is a bit above the burst current of the ESC. So 100A is more than enough for that ESC.
Of course the more the better but the motor determines what is pulled from the battery and of course put through the ESC.Comment
