ul-1 ?
  • Driggs
    • Mar 2010
    • 69
    ul-1 ?
    does the ul-1 have a lipo cuttoff? mine stoped dead in its tracks today i dont know if it over heated or if it has a lipo cuttoff shouldnt it cutt off slowly?
  • Diesel6401
    Memento Vivere
    • 4203
    Yes it does have a lvc which aq refers to as "studder bump" sometimes its hard to catch the "studder" lol. Do you know what the temps where when you retreived the boat? Does it work now with a fresh set of batts? Is it the newer style esc with the HUGE capacitor or the older version?
    - Diesel's Youtube
    - Diesel's Fleet
    • egneg
      • 4664
      What do the caps look like ... are the ends bulged?
      IMPBA 20481S D-12
      • Driggs
        • Mar 2010
        • 69
        im not sure what the temps were, and it has one HUGE CAP, and it does work with fresh battery's, i checked the voltage in the battery's and they where low, so, i was hopeing it was the Lvc, it was the first time i ran it with 2 new 5000 mah, 30c battery's and it was hauling butt, with the reccommended 3 blade grim prop, i just thought it was weird that it just stoped dead
        • JimClark
          • 5902
          How long did you run it for?
          Billy Graham
          • Diesel6401
            Memento Vivere
            • 4203
            I'd assume you hit the lvc then, but we all know what happens when we assume it makes a A$$ of U and ME... lol, im a idiot i know. Try timing your runs and for added insurence install a extra cap on the end of your speed controller a 25v 1500µF will work.
            The information provided HERE should help. I only installed 1 cap and mounted it on top of the controller.
            - Diesel's Youtube
            - Diesel's Fleet
            • Driggs
              • Mar 2010
              • 69
              probably too long, i was haveing to much fun, i was thinking to myself ( man these battery's last alot longer then the 4000 mah battery's) when it happen
              • Driggs
                • Mar 2010
                • 69
                ok well i found out that the ESC was my problem, and i took it to the hobby shop where i bought the boat and they gave me a new ESC , guess what... it has a lot bigger Cap on it then my other one so the boat works like new again, would the boat run about 20 feet and stop with a bad cap or studder and break up under load? just wondering if it was me that caused the problem
                • Rumdog
                  • 6453
                  did you sharpen and balance your prop? A dull, unbalanced prop will load up your motor, causing amps big enough to pop your cap.
                  • longballlumber
                    • 3119
                    Yes
                    Later,
                    MIke
                    • Driggs
                      • Mar 2010
                      • 69
                      the prop is the rec, 3 blade and its sharpened and balanced, hopefully it dont happen again, im kinda scared to run it hard again, im probably going to look into getting some more water cooling in it to be safe
                      • Rumdog
                        • 6453
                        I wouldn't worry about it. Running hard (wot) is actually easier on the esc than half, or mid throttle running. Let her rip man!
