UL 1 Battery
  • davidb
    • Jan 2009
    • 76
    UL 1 Battery
    I just picked up a UL 1 today and have had a supervee before. These forums have been very helpful. I dont race, just go fast. Could someone tell me what lipo to buy please. I am on a buget !
    Thanks dave
  • steve-b
    • Mar 2010
    • 245
    turnigy 5000 2s 40c, use two of these in series.
    • davidb
      • Jan 2009
      • 76
      Steve, thankyou. Best place to buy is where? Also good all around metal prop? I dont race!
      • Rumdog
        • 6453
        25c will be plenty as well. www.hobbyking.com a octura x440/3 is an excellent all around prop.
        • Diesel6401
          Memento Vivere
          • 4203
          Pick a set:
          - Diesel's Youtube
          - Diesel's Fleet
          • davidb
            • Jan 2009
            • 76
            25c or 35 or 40c. Does it matter with these batteries? Maybe it is a stupid question but? Will all of these batteries fit?
            • Diesel6401
              Memento Vivere
              • 4203
              It's the discharge rate. A 40c will perform better than a lower rate. To make it easy on youself stick to 4000mah+ and 25c+ and you'll be ok.
              All the batteries I have listed will fit. I own/use most of them in my ul.
              - Diesel's Youtube
              - Diesel's Fleet
              • longballlumber
                • 3119
                Buy the largest capicity (up to 5000 mah) and the highest "C" rating your willing to spend.
                25C = Good
                35C = Better
                40C = Best
                3700mah = Good
                4000mah = Better
                5000mah(+) = Best
                I think you get the idea... Always keep an eye on those temps during long runs.
                Later
                Mike
                • mike robson
                  • Apr 2010
                  • 430
                  yeah but mah x c = amps and if it puts out to many amps wont it burn up ur esc im new to this brushless thing so if im wrong please help me im used to the mah u got the longer you can play with your truck or car im just now getting in to boats
                  • Diesel6401
                    Memento Vivere
                    • 4203
                    This is one of those cases where you rather have it and not need it, then need it and not have it. Point being the esc will use as amps as it needs from the battery. Amp rating on the esc is continuaous amount of amps from the motor the esc can handle, not the batteries. For batteries more amps the batts can provide the better, it's less straining on the electrics. Hopefully that makes sense. Welcome to boating!
                    - Diesel's Youtube
                    - Diesel's Fleet
                    • mike robson
                      • Apr 2010
                      • 430
                      ok so i need to get me some 40c batteries you sure know how to make the ul-1 fast seen ur video and man thats one fast boat i have a miss elam brushless and just got a ul-1 its alot faster than the proboat had a miss vegas deuce kept havin problems with the hulls so went and traded it in for a ul-1 best thing i could of done i love the brushless boats alot faster than nitro and less the headache.
                      • Diesel6401
                        Memento Vivere
                        • 4203
                        I like the Grim l40x57, it's a lifter prop though so your stuck using it on hydros only.
                        - Diesel's Youtube
                        - Diesel's Fleet
                        • Diesel6401
                          Memento Vivere
                          • 4203
                          Thanks, honestly it's only slightly faster than the stock set-up. I have A LOT of work to do on it and a lot of prop testing to do.
                          - Diesel's Youtube
                          - Diesel's Fleet
                          • BakedMopar
                            No Mo Slipah
                            • Sep 2009
                            • 1679
                            • detox
                              • Jun 2008
                              • 2310
                              40c is not needed. My UL-1 has reached speeds of 50mph using 25c Hyperion lipos. These compact Hyperion 25c 2s 5000mah packs are perfect size, but more expensive.
