Noob and ul-1 w/ lipo
  • 6S HYDRO
    • 1320
    yeah im waiting for stock too. the sv's usually pull alot less but everything depends on how big a prop your runnin and how many kv motor
    • Diesel6401
      Memento Vivere
      • 4203
      If I did go parallel how would I go about it. Grab this adaptor from OSE http://www.offshoreelectrics.com/pro...od=dh-gpmm3142 and disconnect the series jumper from the two esc connectors and just solder the two wires from the esc to one connector? Basically get rid of the two battery connections and make one and use with this adaptor. Just weighing my options and gaining knowledge.
      - Diesel's Youtube
      - Diesel's Fleet
      • 6S HYDRO
        • 1320
        no you can flip the deans opposite and fit one pos. end in the one hloe and one neg. in the other its hard to explain - but you dont have to go to a single deans-hence you can still run series packs as well
        • 6S HYDRO
          • 1320
          ill take a pik
          • Rumdog
            • 6453
            Be careful with the SV. It does not have a low voltage cutoff.
            • 6S HYDRO
              • 1320
              • Diesel6401
                Memento Vivere
                • 4203
                I installed a dimension engineering lvc as well as a cc bec. My SV is just an electrical hazard lol. Gotta love it
                - Diesel's Youtube
                - Diesel's Fleet
                • Diesel6401
                  Memento Vivere
                  • 4203
                  #23
                  WHOA that looks crazy 6s, so both batts plug into the bottom i assume and where do the 2 connectors for the esc plug into? I only see one female input at the top for esc? Could I do it the way I decribed above though? Please bare with me. Funny part is that am an aircraft mechanic and rc boats make me think more than planes do...lol
                  - Diesel's Youtube
                  - Diesel's Fleet
                  • 6S HYDRO
                    • 1320
                    #24
                    that was just an example, you would use the one from offshore and your regular leads comin out from your esc. thats how you plug 2 deans into a single parralell port
                    • 6S HYDRO
                      • 1320
                      #25
                      just what i had layin around to show you with, i dont use deans anymore and have moved srictly to 5.5mm bullets
                      • 6S HYDRO
                        • 1320
                        #26
                        Originally posted by 6S HYDRO
                        i would never run this setup- too much resistance, just shows you how to flip series deans to one single parallel plug
                        • Diesel6401
                          Memento Vivere
                          • 4203
                          #27
                          That connector from ose only has 1 input for the esc though correct? So just install red wire for esc into + side of the connector and have the - left out and do the opposite for the other connector? I wish I could better explain what am trying to say. bascialy one side of each connection from the esc would be left unplugged. that way I could easily change back in forth between series and parallel? Am i close?
                          - Diesel's Youtube
                          - Diesel's Fleet
                          • bwells
                            • Jan 2009
                            • 842
                            #28
                            Wow. 6S: is that connector UL approved? That was a lot of work to make!
                            • 6S HYDRO
                              • 1320
                              #29
                              you are correct
                              • 6S HYDRO
                                • 1320
                                #30
                                no its not UL, all im showing is a series connector and a parallel connector hooked together to show diesel- dont run this contraption shown
