Motor keeps frying out.....
  • FEJohn
    • 25
    Has anyone had any problems with there motor frying out? I'm on my second one now and I bought the boat in July. I am using the factory water jacket. When I turn it on and hit trigger the prop spins very slow (even with fresh packs)but there is a noticable grinding sound coming from the motor. Can anyone help me out with this? Is the
    Motor really burned out or is this something else?
    Aquacraft UL-1
    Aquacraft Rio 51 Gas (modified)
    Zipp Kits Easy Vee
  • Ub Hauled
    • Aug 2007
    • 3031
    it could be the speed control... did you test the motor prior to launch or on a different ESC?
    • eboat
      • Aug 2007
      • 693
      does the flex shaft turn freely when the motor is not hooked up ?
      • Darin Jordan
        • 8332
        Are your motor mounting screws too long???
        Darin E. Jordan - Renton, WA
        • FEJohn
          • 25
          Yes, I did test the motor before launch and the "grinding" sound did happen. If i wanna test the ESC could I do it on any ESC made for a BL motor. Could I use my traxxas one? Or does it have to be the another aquacraft ESC
          Aquacraft UL-1
          Zipp Kits Easy Vee
          • FEJohn
            • 25
            I dont think my motor mount screws are too long. They are the stock screws.
            Aquacraft UL-1
            Zipp Kits Easy Vee
            • Ub Hauled
              • Aug 2007
              • 3031
              IS the coupler rubbing against the motor mount?
              if you are using a BL motor, the ONLY a BL ESC will work.
              DO NOT USE A BRUSHED ESC WITH A BL MOTOR
              Same goes the other way around.
              • Ub Hauled
                • Aug 2007
                • 3031
                What Darin was suggesting is that as you screw them on you HAVE TO MAKE SURE that the screws DO NOT touch the wires, it'll short the motor out, it does not matter if the are stock screws or not.
                Take the motor out and place the screws in the holes you have not used and gently go in as far as you can and see how much of a gap is left when you gently touch the wires.
                BE GENTLE.
                • BakedMopar
                  No Mo Slipah
                  • Sep 2009
                  • 1679
                  Try checking the bullet connector connection between motor and ESC. Make sure the connection is solid.
                  • Darin Jordan
                    • 8332
                    I suppose one should also make SURE the driveline is free... Make sure the shaft is well lubed, and spin it without the motor attached to verify that it's not binding or ???
                    • FEJohn
                      • 25
                      Thats what my LHS said. I think I wasnt lubing the drive shaft enough. They told me to do it after every run. Im used to gas boats that dont really require it after every run
                      Aquacraft UL-1
                      Zipp Kits Easy Vee
                        • 7990
                        It is NOT necessary to lube the cable after every run if you use a decent oil or grease. If the teflon liner is damaged that could cause both noise and extreme drag which can overheat the motor. These motors are simple and pretty foolproof, if you have destroyed two of them, something else is wrong. The suggestions about long screws and something rubbing are good ones. Did you ever run the motor at full throttle out of the water for more than a few seconds? FE motors are not to be revved to maximum without a load, that can cause permanent damage.
                        • LiPo Power
                          DJI Drone Advanced Pilot
                          • May 2009
                          • 3186
                          ...FEJohn, so did you test your motor on diffrent ESC?
                          Canada
                          • D. Newland
                            • Dec 2007
                            • 1030
                            Yes.
                            They've got a 90 day warranty.
                            I have found on 2 occasions that a part of the rotor has come loose, making contact with the outer motor windings.
                            Does the motor smell burned?
                            I'd plug everything up, minus the drive shaft and coupler and bench test the motor. Don't go full throttle, but just blip it 1/2 throttle quickly. See if the motor RPM's come up smoothly, or not. See if the motor seems normal under deceleration. You'll know PDQ if the rotor is making contact with the outer windings. If it starts chunking/coughing/sputtering, there's a problem.
                            Also, as mentioned above, the ESC would be the next thing to trouble-shoot. In fact, I think it would be better to check YOUR ESC against a fresh motor, rather than ANOTHER ESC against your "damaged" motor. You may end up with another damaged ESC.
                            • longballlumber
                              • 3119
                              John,
                              Where are you located in MI? If your in the Metro Detroit area, I may be able to help if needed. Try the tests that Mr. Newland has recommended and see if you can make any findings of what is good or bad. It sure seems like something is not right causing 2 motors to go bad. Feel free to PM me if you need.
                              Mike Ball
