it's here!
  • racer1
    • Aug 2009
    • 24
    i have run it with and without those fins. I put them there in hopes of holding the nose down. now no matter what I do and how I adjust the drive and weight at about 30+ it stuffs the nose. I'm clueless cause I have tried less weight in the front and the torque rolls it over and adjusting the drive to pitch the nose up and it skips all over the water and is completely un-controlable. If you have any insight it would be great.
    SV 27 Brushless - Rio 51 - Mini Thunder - Commander II - Skunk Works Mini Bullnose
    • domwilson
      Moderator
      • 4408
      What prop is that?
      Government Moto:
      • JimClark
        • 5907
        Never noticed the two turn fins why on earth did you do that? that would cause more problems in handling.
        Billy Graham
        • JimClark
          • 5907
          Probably an x430
          Billy Graham
          • Rumdog
            • 6453
            What's the "plate" near the front of the hull?
            • racer1
              • Aug 2009
              • 24
              you can't tell in the picture bot the "plate" is actually stick on lead to add weight to the front. The prop is an octura X432 I'm gonna take off the two fins cause you're right it didn't help.
              • SPISHAK
                • Aug 2009
                • 27
                Should the prop be that far out back on this tiny little pond skimmer? I've been lurking around these mini thunder threads trying to decide whether this should be my first hydro. (I have access to a tiny pond, and can't go with anything much bigger or faster) TIA
                • SPISHAK
                  • Aug 2009
                  • 27
                  #23
                  The stock motor and esc lasted one run.
                  They burned up on first run?
                  • SPISHAK
                    • Aug 2009
                    • 27
                    #24
                    how much water gets inside of these buggers?
                    • SPISHAK
                      • Aug 2009
                      • 27
                      #25
                      I am using the brushless motor and esc from the Helimax MX400 Pro
                      will that motor fit the stock coupler/shaft/whatever you call it that goes to the stock prop? The only mods I plan to do are BL conversion and bigger turn fin.....just want a bit more speed and better turn bite. TIA
                      • racer1
                        • Aug 2009
                        • 24
                        #26
                        it didn't burn up, it just wasnt fast enough for me. If you don't tape it up a considerable amount of water gets inside but everything is "waterproof" I tape mine and I only get a little from the stuffing tube. I don't know what motor will fit the adapter right except for what I put in but you have to make a spacer for the strap that holds the motor cause it's a little smaller diameter.
                        If you go brushless I recomend that you only run up to 3000 kv and a 2 cell lipo or you start running into major stability issues withous serious modification (as you can see by the pictures)
                        as for the turn fin, just drill new holes in the boat and lower it like 1/2 inch. if you havea vice you can also put like 20-30 degrees of hook in it to hold the side down when you corner.
                        Here is a link for the motor.....Hope I could help.
                        Tower Hobbies carries an expansive collection of RC cars, RC airplanes, RC boats, model trains, sot cars, and supplies for all hobbyists.
                        • SweetZ28
                          • 1322
                          #27
                          Mine feels pretty quick with the T-400 motor installed..... and it runs cool so i bet you can use a little bigger better prop and that to will make it a little faster.
                          WWW.PPRSLOTS.COM
                          • SPISHAK
                            • Aug 2009
                            • 27
                            #28
                            What size is stock? What size would you suggest? I'm new and this is my first boat. TIA
                            • SweetZ28
                              • 1322
                              #29
                              Go on aquacrafts web site and look at the mini thunder and at the bottom they list hop ups and the T-400 is shown ...I used it and it makes the boat a nice swift speed.
                              WWW.PPRSLOTS.COM
                              • SPISHAK
                                • Aug 2009
                                • 27
                                #30
                                I was talking about the prop! My mini was just delivered and it does not look like a bigger prop will fit under there. I will keep it stock but with the T400 motor and 1600mah bat from the upgrade list.....and a maybe a bigger turn fin. I will also start on a custom paint scheme.
