AquaCraft Miss Seattle U-16 2.4GHz RTR
  • Diegoboy
    • Mar 2007
    • 7244
    Unlimited Racing Excitement!
    The thunder, the roar, the solid wall of water as the boats tear past, skimming just above the surface. It's not hard to see why people love Unlimited Hydroplane Racing. With the U-16 Miss Seattle RTR Brushless Hydroplane, you can bring that excitement to a lake or pond near you! It arrives pre-assembled, loaded with a powerful brushless motor, equipped with a kick-back rudder safety system and totally ready to kick up some spray!
    This boat shares many parts with the GP-1 by AquaCraft
    FEATURES:
    • New Tactic TTX300 2.4GHz transmitter with lightweight TR325 receiver.
    • 2200kv brushless in-runner motor with aluminum water jacket.
    • LiPo-ready (3S) 30 Amp brushless water-cooled motor controller with low battery warning system and battery cut off circuit.
    • Tough, light-weight ABS construction with square hatch opening for easy taping.
    • Great-looking, pre-applied Miss Seattle graphics.
    • Adjustable strut
    • Music-wire drive shaft
    • Pinch wire motor coupler
    • Break-away wedge rudder
    • One-piece aluminum turn fin
    • 1/8" [3.2mm] prop shaft
    • Two blade 30mm FRP propeller
    • Transom drain plug
    SPECIFICATIONS:
    • Stock Number: AQUB1822
    • Hull length: 16.75 in (425 mm)
    • Overall length: 18 in (458 mm)
    • Width: 8.5 in (216 mm)
    • Height: 4 in (102 mm)
    • Weight: 17.1 oz (485 g)
    • RTR requires: 11.1V 1000mAh LiPo battery, charger, safe charge sack & 4 "AA" batteries
    MOTOR SPECS:
    • KV rating: 2200kV @ 11.1V
    • Operating current: 1.4A, 8V/DC (without loading)
    • Input: 8 to 14V
    • Max current: 28A/15 Seconds
    • Shaft diameter: 3.2 mm (1/8")
    • Motor resistance: 50 m
    • Dimensions: 27.5 × 30mm (1.1" × 1.2")
    • Weight: 71 grams (2.5 oz)
    ESC SPECS:
    • Rated Current: 30 amp
    • Battery Connector: Deans® Ultra Plug ®
    • Motor Connector: 3.5 mm Bullet Plugs
    • Wire Gauge: 14G
    • Warning System: 9.6V Stutter Bump
    • LVC: 9V
    • BEC Max Current: 2A
    • PWM: 8K
    • Dimensions: 1.8" × 0.9" × 0.4" (45 mm × 24 mm × 9 mm)
    Manual PDF
    VIDEO:
