AquaCraft Mini Wildcat
  • BakedMopar
    No Mo Slipah
    • Sep 2009
    • 1679
    Anybody has one? Thinking about getting one of these for my daughter.
      • 9479
      I had a Mini LST2 that I changed out the esc and used a decent 10th scale esc and ran the truck on 3s with the stock motors and that little truck moved very well.
      IMO just as fast as some have gone using brushless on 2s but much cheaper
      so maybe the same mod on this could wake it up!
      • Diegoboy
        • Mar 2007
        • 7245
        Anyone notice how the hatch magnet is on the front? I don't think that was a positive change in design. Not a big deal with the stock power plant (guess @ 8mph) but mod her for brushless counter rotating, and you may loose the top easily.
        just a thought...
        • 6S HYDRO
          • 1320
          its gonna have to be cut out and taped to modify these things at all. the must have been assembled before the hull was joined.
            • 9479
            I don't see a magnet, looks more like two pins and a latch
            • Diegoboy
              • Mar 2007
              • 7245
              You're right. I found & posted that while driving, so I couldn't stare at it too hard
                • 9479
                while driving!
                • j.m.
                  • Jul 2008
                  • 838
                  #23
                  It's in stock at tower hobbies...
                  • blastoff
                    • Apr 2008
                    • 155
                    #24
                    Could you swap wires on one motor to get it to counter rotate using the stock speed controller ??? Or would the stock controller burn up ??? Or not spin one motor backwards ???
                    What size prop are they running ???
                    Can you add a bit bigger battery ??? If all this is possible then the mini cat would shred !!!
                    Are there plans on building a bigger version ???
                    • blastoff
                      • Apr 2008
                      • 155
                      #25
                      • NOZ69R
                        • Apr 2010
                        • 37
                        #26
                        One motor stopped working
                        Has anyone experienced one motor stopped working?
                        We had three brand new ones ALL have this issue on the weekend 2x L/H & 1 x R/H with one of them being the local Hobby shop guys.
                        He suspects a bad batch & is going to send all of them back.
                        Cheers
                        The older I get the BETTER I was..
