Beautiful piece of property.
Just joined the MC crew!
What rescue boat is that? AquaCraft Atlantic Harbor tug? Did you make the retrieval hooked float or did you buy it like that?TFL Zonda (124mph), Miss Geico Zelos 36 (108mph), Veles 29 (91mph), Zelos Twin 36 (90mph), Miss Geico 29v3 (83.5mph), Sonicwake 36 V2 (83mph), Blackjack 42 (81mph), TFL Pursuit (79mph), UL-19 (75mph), Sonicwake 36 (73mph), Motley Crew (47.5mph), AquaCraft Rescue 17Comment
That is the Hobby Engine Southampton tug, which now Tower sells. The only thing I left alone are the motors. Twin 280 brushed. I installed a better steering servo, esc, and the Spekky radio. She'll pull over 100lbs. I run it on 3s. The retrieval float is from Billy Boy Bobbers and made from balsa. It's attached to the tug with 10 feet of 20lb. test fish line. The hooks are just steel hooks I got from Walmart. They have threads on the one end, so I opened the hooks some and screwed them into the float. Got the rubber caps for the hook ends from ebay.Comment
Thanks for the info! What ESC did you use in the HE tug?TFL Zonda (124mph), Miss Geico Zelos 36 (108mph), Veles 29 (91mph), Zelos Twin 36 (90mph), Miss Geico 29v3 (83.5mph), Sonicwake 36 V2 (83mph), Blackjack 42 (81mph), TFL Pursuit (79mph), UL-19 (75mph), Sonicwake 36 (73mph), Motley Crew (47.5mph), AquaCraft Rescue 17Comment
What really sucks that I didn't do when I first got it was to buy a pair of kort props for it from the Prop Shop. It has kort nozzles, but standard style four blade props. With the kort props it would have a lot more pulling power. But it looks like the Prop Shop is done since they had that fire back in April.Comment
The floats I have found are made of foam. You said yours is made from Balsa wood right? See the links below and point me in the right direction, if you don't mind. Is yours the .050 size (like 5x3 inches)? Looks like these are all foam.
https://www.amazon.com/gp/product/B0...KIKX0DER&psc=1Last edited by MADRCER; 06-17-2017, 10:25 PM.TFL Zonda (124mph), Miss Geico Zelos 36 (108mph), Veles 29 (91mph), Zelos Twin 36 (90mph), Miss Geico 29v3 (83.5mph), Sonicwake 36 V2 (83mph), Blackjack 42 (81mph), TFL Pursuit (79mph), UL-19 (75mph), Sonicwake 36 (73mph), Motley Crew (47.5mph), AquaCraft Rescue 17Comment
https://www.amazon.com/gp/product/B0...KIKX0DER&psc=1Comment
Thanks! That's the one I thought it was. Might get one and play around with it.TFL Zonda (124mph), Miss Geico Zelos 36 (108mph), Veles 29 (91mph), Zelos Twin 36 (90mph), Miss Geico 29v3 (83.5mph), Sonicwake 36 V2 (83mph), Blackjack 42 (81mph), TFL Pursuit (79mph), UL-19 (75mph), Sonicwake 36 (73mph), Motley Crew (47.5mph), AquaCraft Rescue 17Comment
Here's the one I bought. It was a good experience. http://www.ebay.com/itm/351977013045...%3AMEBIDX%3AITComment
Thanks. Any info on the hook slip covers? size?TFL Zonda (124mph), Miss Geico Zelos 36 (108mph), Veles 29 (91mph), Zelos Twin 36 (90mph), Miss Geico 29v3 (83.5mph), Sonicwake 36 V2 (83mph), Blackjack 42 (81mph), TFL Pursuit (79mph), UL-19 (75mph), Sonicwake 36 (73mph), Motley Crew (47.5mph), AquaCraft Rescue 17Comment
You da man! I would have never guessed them being antenna tube caps!TFL Zonda (124mph), Miss Geico Zelos 36 (108mph), Veles 29 (91mph), Zelos Twin 36 (90mph), Miss Geico 29v3 (83.5mph), Sonicwake 36 V2 (83mph), Blackjack 42 (81mph), TFL Pursuit (79mph), UL-19 (75mph), Sonicwake 36 (73mph), Motley Crew (47.5mph), AquaCraft Rescue 17Comment
