Please help with setup
  • MAMBA2200
    I need a scooby snack
    • Jul 2012
    • 1202
    ok so i had the MC out for the second run yesterday and it did ok but i had raised the strut and its very slow on take-off but ran decent on top end only 35mph i have the strut about 1/8th up with 0 degree's of rise but this boat should be in the 40's running 3674 leopard 1900kv seaking 120a esc and 42x55 prop on 5000mah 40c packs any help would be appreciated
    Im Only Responsible For What I Say Not For What You Understand
  • 100 mph jet boat
    • Apr 2012
    • 121
    did you program the esc??
    my mc runs best with the strut level
    • MAMBA2200
      • Jul 2012
      • 1202
      yeppers when it was level it would not get on plane
      • MAMBA2200
        • Jul 2012
        • 1202
        here is the video
        • lenny
          • Sep 2010
          • 4294
          What is the timing set at on the esc ?
          ? ONLY IF THEY WORK
          • MAMBA2200
            • Jul 2012
            • 1202
            im thinking 7.25
            • G-UNIT
              • 949
              I have the same motor and was told to set the timing to the lowest setting as its a d wynd.
              forgot what it is, 3 degrees ?
              ps. I always like your vids.
              • MAMBA2200
                • Jul 2012
                • 1202
                i will try the lower timing thanks for watching my vids
                • G-UNIT
                  • 949
                  Yea nice fleet, what, you have a revolt, mc, mistic and a impulse, but no ul-1 whatsup. ha, ha.
                  • MAMBA2200
                    • Jul 2012
                    • 1202
                    not much on the hydro boats cool to watch and yes that is the 3 boats i have really got my mystic hauling a$$ yesterday uploading a vid now but its short cause i blew a cap on my bec think it got wet for some reason i got allot of water coming from somewhere now
                    • 100 mph jet boat
                      • Apr 2012
                      • 121
                      what is you cog??
                      set timming at 3 - 3.5
                      most mc i have seen take a little bit to get on plane Not all of them but most of them.
                      • MAMBA2200
                        • Jul 2012
                        • 1202
                        cog is about 30-35% i will try lowering the timing sunday
                        • 100 mph jet boat
                          • Apr 2012
                          • 121
                          put your batterys as far back as poss.
                          • Rocstar
                            Joel Mertz
                            • Jun 2012
                            • 1509
                            I would lower the strut back down a bit. Sounds like the prop is running a bit shallow in the water. Make adjustments with your cog to get her flying level.
                            • 100 mph jet boat
                              • Apr 2012
                              • 121
                              X2 I ment to say that aswell but hit post
                              Good call Roc
