This is my first boat, but I've been into RC cars, trucks, an Heli's for years. So I need your guys advice.
I just bought an MC off the F/S area on this forum. It came with a Traxxas waterproof servo, CC Hydra 120a ESC, Leapord 4074 2200kv, an OSE FG motor mount with rear ring, Octura X445 B/S.
Well since the motor was aligned horribly. I tore the boat down to a bare hull. And now I'm going to CF the inside of the hatch and the front 1/2 of the tub where the motor is going, and align it right this time. Putting in the OSE upgraded shaft. And putting 5.5mm Connectors on everything. And some other upgrades I need your help with.
1. What is a direct drop in dual water pick-up rudder? I wanna have a single line to the esc and motor. The water temp gets hot down here in Southern Oklahoma. Or just keep the stock one, and run a splitter?
2. On the ESC I got, will I need a BEC when I run 4s?
3. What timing should I run with the Leapord 4074 2200kv?
4. What are some of your guys prop suggestions? I do have the X445, is it to big?
5. Should I foam inside the hull?
6. What kind of speed should I see out of this setup? Running 4s2p 5000mha(maybe haven't bought them yet)
I'm sure I will have alot of other questions later on. Thanks in advance.
