Motley Crew Leopard 4074 install
  • Diesel6401
    Memento Vivere
    • 4204
    I have filled hulls before with the home improvement foam. Worked fine for me. You just have to have places for the excess foam to escape. If it expands to much with no place for the excess to go it will split the hull. Good move on the 5.5 for the batteries. I am also using 6.0mm bullets from Hobbyking. They are truly awesome connectors, way better then the HK 5.5 bullets and more on par with cc 6.5s.
    - Diesel's Youtube
    - Diesel's Fleet
    • Pete32200
      • 238
      Kintec sells small quantities of the 2 part marine foam, I will have to pick some up next time I am there.....Maybe I will go ahead and foam the UL-1 also
      VS1 FE - UL-1 - Motley Crew - Miss Geico - Kintec Prince - Rio 51z - 1/16 Summit - 1/10 Summit - Ken Block Rally - Kyle Busch Truck - Losi Mini SCT - BL E-MAXX - Assoc FT SC10 - Wild Willy - Clodbuster - Sand Scorcher......
      • JPriami
        N4FOX
        • 1675
        Use a little at a time. Too much and it will expand then the outer layer will dry and harden. Leaving some trapped inside that's not cured. Then when it heats up it will expand and pop goes the hull. I am speaking from experience. But I managed to save it because I caught it before it busted. I poked holes in the foam letting what was trapped and expanding to have a way out. Now it's all fully cured and has added more strength to the hull of my MG.
        Btw if anyone gets the spray stuff get the blue can.
        • bruce5385
          • Jul 2011
          • 52
          same happened to me. old supervee had nice buldge in nose. lol but the home improvement stuff will hold water(if u cut the dried foam it leaves it were water will absorb in foam) that was with the red and yellow greatstuff though.
          • Pete32200
            • 238
            Now I am afraid to try it !!
            • Pete32200
              • 238
              What is a good timing setting for the 1800kv 4074 leopard?
              • JPriami
                N4FOX
                • 1675
                I emailed leopard hobby about those motors to find out if they are a D or a Y wind motors. They said it's a D wind
                D winds are normally 0-5 low 5-10 med deg of timing
                Y winds are 0-10 low and 10-15 med deg of timing.
                • Diesel6401
                  Memento Vivere
                  • 4204
                  #23
                  WOW now that's interesting. My Leopard 4074 1774kv ( i guess this 1800kv replaced it) was actually a wye wind and likes 15* timing. Interesting on that and good info. I guess to be safe run at 7.5 on the timing. Kinda that happy medium between both winds. I ran a Tacon (leopard clone) delta wind at 7.5 and it ran very VERY well at that setting.
                  - Diesel's Youtube
                  - Diesel's Fleet
                    #24
                    I emailed leopard hobby about those motors to find out if they are a D or a Y wind motors. They said it's a D wind.
                    All the other 4074s are apparently Y winds, see here: http://www.leopardhobby.com/product/...ionID=01020201
                    The Y motors like timing, the amount depends on the load. I would not run more than 5* advance on a D wind as it just generates excess heat, not power (except in outrunners, but that's another subject).
                    • Diesel6401
                      Memento Vivere
                      • 4204
                      #25
                      I use to have a much more detailed print out of Leopards chart. They started changing a lot and removing a lot of data so I printed it a while ago, it had both y and d winds information on it. Now the real issue is finding what i did with the print out
                      - Diesel's Youtube
                      - Diesel's Fleet
                      • Pete32200
                        • 238
                        #26
                        I went to an M645 prop and 5.5 bullets on the batts ( and picked up another pair of 2s 5000mah 40c turnigys while I was at Kintec Racing today....I love having a full service R/C boat shop near by ... Set the esc timing to 3.5 degrees and headed to the lake, My Nuvi 200 GPS said 49mph and it seemed a little faster without the weight of the huge GPS crammed in there, So I am assuming I am at right at 50mph. The motor and esc temps were less than 120 degrees, however the 5.5 bullets on the motor got to 165 and were smoking.....and the 5.5 bullets on the batts were at 135.....when I run with the deans on the batts the deans connectors are only at 125 degrees. would some di-electric grease help or hurt the connection?
                        I also picked up some 2 part foam to do the MC and my UL-1, I should have some pics up of that process this weekend
                        • Pete32200
                          • 238
                          #27
                          Got the foam in the hull last night, I originally was just going to drill a couple 3/4" holes to pour through but found a piece of foam in the nose ( and it was holding alot of water ) so I cut a slot large enough to slide it out, it wasn't glued in or attached at all, it just pulls out
                          After removing the stock piece of foam I could see plywood sheets running flat inside the sponsons front to back, they have large holes in them so the foam will pour right throught them without issue
                          I started by mixing 1oz of part A and 1oz of part B ( 2 oz total ) and did my first pour, Waited 30 minutes and Repeated that process 2 more times for a total of 6oz ( 3oz part A and 3oz Part B ) that got me very close so for the final pour I mixed 1/2oz of each and that filled it......I thought
                          Apparently there is a piece of plywood or some other material that runs across the nose and prevented the foam from filling up the front 2 inches of the hull......THE MOST IMPORTANT PART !!!!
                          so If you are going to fill the hull get in there with a long drill bit and put some holes in there for the foam to pour through, I need to figure out the best way now to get foam in the nose
                          • JPriami
                            N4FOX
                            • 1675
                            #28
                            Nice job
                            • JPriami
                              N4FOX
                              • 1675
                              #29
                              On the connectors getting hot try spreading the prongs out to make sure they fit snug. Maybe even go over them with fine steel wool to make sure they don't have anything stuck to them. I imagine the dielectric grease idea wouldn't hurt.
                              Checking the soldering connections by re-soldering if that don't help.
                              • detox
                                • Jun 2008
                                • 2318
                                #30
                                This hull is begging for more kv. The Neu 1515 1y (2200kv) or Castle's 1515 1y. Of course maybe a leopard 2200kv motor.
