Alright, well; bottom line the lake water is really warm here in the south during the summer months. Last weekend I temped the water out at 98 degrees!!! Not to mention, the water cooling system on the AC MC leaves much to be desired. The water pick-up is small, and the tubing has a small I.D. So I went and picked up a couple of traxxas water pick-ups which are MUCH larger than the stock AC MC pick-up. I also grabbed some 1/8" I.D fuel tubing. I put the motor and ESC each on their own separate water loop and I also moved the outlet's to the side of the boat. I mean, who can even see the stock unit shooting water out of the back of the boat anyway? You can't. But, I am sure i'll be able to see it now!!!
I also had to move the hull plug. I did hack it up a bit before I moved it, thinking I might be able to leave it. No dice. It looks a little funky, but it still works. I'll order a new one later....
Anyway, here are some pics. I am hoping this will improve my cooling performance. As it stands now with the warm water, I can't run a M445 for a full 3.5 minutes. My gear will start to burn up..... I am hoping I can now.
