Hi guys i just got my new power system for my MC and would like to get this thing in the water asap, I still haven't got an upgraded shaft from ose (will soon) and was wondering if anyone has had luck with the stock shaft or if theres something i oculd do to test it or "fix" it so it doesn't fail?? thanks
MC flexcable fix?
Run it with the stock shaft and stock prop. So if there is a problem you dont lose an expensive prop. I dont think every shaft is bad. Most of them are probably fine. But a very bad ones seem to ruin the lot.Steven Vaccaro
Where Racing on a Budget is a Reality! -
Where exactly are they breaking or coming off? Are you calling AquaCraft about the issue?Steven Vaccaro
Where Racing on a Budget is a Reality!Comment
They are coming off at the flex and prop shaft connection. 2 have fallen completely off and 2 just spun so I was able to keep the prop and so I pulled them apart and re soldered them and So far they have been fine I also bought ose flex cable for the other 2. My buddy drove his today for the first time and his prop fell off with in 20 ft. No I have not talked to aquacraft I just fixed them.
Well I got one and 4 of my buddys got the mc so we have been racing good timesComment
I just got my flex shaft from AQ I just took it apart and flipped the flex around and put it back togetherBrapppComment
I ran 5 runs before mine came out.... the solder was not completely through the flex shaft. It didnt snap..... it just came apart.
I was running 5s with the Ul1 stock plastic 3 blade for 1 complete run (It was running awsome). I sent it out again for second run I brought it in to check temps, I was about to put the grim 40/52 3 blade on but instead, i just finished the run when it let go.
(glad I didnt put the metal prop on)
ive got my new MC cable on the way!!Aeromarine Challenger,Warehouse hobbies Man O War, Traxxas Blast Rescue Rig, AQ UL-1 Yellow, BE REVO,T-Maxx, Vorza, Baja5B, and the latest addition Baja5T,Wife's gunna keel mee!
You separated the shaft from the flex, flipped the flex cable and re-attached the shaft to the flex? Am I understanding that correctly? Because if that's what you did you just made your stock CCW cable a CW cable which means the cable is going to unravelComment
I thought about that but it won't if I put the old cable next to the new one the twist is in the same directionBrapppComment
Attached FilesComment
