I have a Revolt 30 and a Motley Crew. I would like to consolidate my boats to one radio. I am not unhappy with the Tactic radios I just don't want to carry more than one radio.
With that being said,
-What radio would you guys recommend?
-The tactic receiver does not have an antenna and I noticed that the Spectrum marine receivers do. Does this mean that I will have to run the antenna through the hull or can i tuck it inside the hull and still get a good signal?
Thanks!
Thanks!
, I also think it depends on the level of the boater, i am strickly a sport/basher. I use a number of rx binded to a single tx.,(Tactic). I put pencil marks for individual settings, having said that, all the ESCs are Seaking and I find no need to re-adjust the throttle trim, there is no end point adj. on this tx anyway, the only things need to be concerned with are rudder trim ( centering ) and sometimes this channel needs to be reversed---easy to do. In the event that you suspect the throttle calibration is off, you can always re-calibrate. I would think this is a headache for advanced boaters or racers.
