VS-1 and FE
  • Grimracer
    • Nov 2008
    • 662
    VS-1 and FE
    For those of you racing your VS-1s as a FE boat what do you think about the boat overall?
    Maybe provide us with some setups and race results.
    Grimracer
  • Rumdog
    • 6453
    A FE version would be awesome IMO!!
    • Shane_744
      Choppin' it up
      • Sep 2009
      • 92
      A FE VS1 is my dream boat. I just don't know enough about FE boats to make myself one yet.
      TEAM Crawler Innovations, TEAM Holmes Hobbies, TEAM BC Paints!, TEAM OTTSIX , TEAM Y-Town Crawlers
      • Ub Hauled
        • Aug 2007
        • 3031
        Mike, I personally don't own one,
        from what I have seen from Tony, it's
        a very nice platform, stable, corners well,
        can take the OPC power with grace and does not
        require a boat load of tweaking to do so.
        I am not sure what kinda changes the boys up north
        are doing to their hulls, but Tony was telling me they are very fast...
        it would be nice to hear their opinions and perhaps some of
        the mods they have done to achieve such feat.
        • properchopper
          • 6968
          Mike, I've owned and raced two TS-2's ; one with stock and one with modded bottom. Took a first in class at WW IV with the stock one. David Newland does superbly with his TS-2.
          I Switched to the VS-1 and like it way better. The main difference I've noticed is that the VS-1, besides being faster in the straights, corners flat, the TS-2, no matter what I've tried, hops in the corners. Viva 'la VS-1 !
          The only mod from stock on my VS-1 is a notched transom to get the pivot pin further indide the rear sponsons. Not sure this was necessary, but you've previously mentioned this. Hyperformance angle drive with lengthened fin, UL-1 motor, Zippy/Flightmax 4S 30C 5000/ Grimracer 42/55 de-tounged & mildly cupped.
          Hydra 120 ( 'cause I had one sitting around).
          I've watched Brian just SHRED the 2-lap with the same setup using the Bullet drive, which will be my next choice. { his prop was "special" of course.}
          The build was time consuming ; radio box & seven waterproof pass-throughs in back. A dedicated FE version with these pieces in place would be sweet ! [ hint, hint]
          • cybercrxt
            • 2909
            Grim, I have built two FE VS-1's. The first one I sold to Hugh Ebner, he just placed 2nd at a florida race a couple weeks ago. My new VS1 FE is actually a better design than that one. The boat will run full speed threw a 25ft diameter circle with no issues. The boat is extremely stable and DOES NOT BLOW OFF! I had terrible luck with the VS1 as nitro but as FE its perfect! I use an REK lower, prather mount, hyperformance FE conv, flex, and propshaft, ul-1 motor, turnigy 120a boat esc, and flightmax zippy 4 cell 5000 pack. The boat radars about 48-50 mph with your 42X55 stock, unmodded prop. Its a great setup. I am working on setting up a vision 20, sniper 20, htb 290, and leecraft xtr-21 right now. I have the hulls, just not all of the electrics yet. Once I have all of those done I will be doing a little race test of the 5 boats! Should be fun! Mike
            • Shane_744
              Choppin' it up
              • Sep 2009
              • 92
              ^^^^ Pictures??? ^^^^
              • cybercrxt
                • 2909
                I will put them up tonight. I am working from my phone right now and it would take all day to post them! They are on my photobucket, user name spoonefcrx. You might be able to find them that way. Mike
                • 6S HYDRO
                  • 1320
                  i have problems with mine rolling sometimes in the turns over wakes. should i move cg toward the rear?
                  • properchopper
                    • 6968
                    Not sure what to tell you. I remember at WW V when Dick Roberts & me were side-by-side in typical racewater conditions in turn one & we both rolled at the same place at the same time.
                    • 6S HYDRO
                      • 1320
                      so its a common problem
                      • 6S HYDRO
                        • 1320
                        how much does the nitro motor and lower weigh compared to a electric setup, i use a rek lower and bj combo
                        • properchopper
                          • 6968
                          I don't know, maybe Mike {Cybercrxt} does.
                          • 6S HYDRO
                            • 1320
                            im wondering if i add some lead to the motor if it will help this
                            • properchopper
                              • 6968
                              The lower the weight, the better the anti-roll effect.
