TFL Twin Mini Zonda 2960/2400KV 4s choosing props
  • Addicted
    • Jul 2023
    • 90
    The boat is coming soon with some junk brass props and I want to get a couple sets of CNC props. What would you guys recommend for 4s runs and 6s. I was thinking a set of 3814 6s and 4014 4s. I do have a set of 4214s as well. Do you guys think the 42s are too big for 4s? It's got Seaking 120s.
  • 1coopgt
    • Feb 2019
    • 414
    Interesting, this is the first I've heard of a Mini Zonda. Actually had to Google it. Only 27in long. should be interesting on 6s . Unfortunately I can't help you with prop sizes . Usually I contact DASHBOATA with prop questions.
    • fweasel
      master of some
      • Jul 2016
      • 4285
      A twin Mini Zonda makes my head hurt. There was barely enough room in that hull for a single motor and two batteries in mine. Good luck. Mine ran 92mph on 4S with a single motor, but needed perfect water conditions because the hull was so small.
      Vac-U-Tug Jr (13mph)
      • Addicted
        • Jul 2023
        • 90
        My head is hurting trying to tune this Mini lol
        Its hopping for some reason. Thinking of going to an inward rotation on the props.
        TFL twin Carbon Fiber Mini Zonda maiden run (youtube.com)
        • OceaneEmmerich
          • May 2025
          • 1
          With this system, you should start with a 38mm x 1.4 CNC, then test up to 40mm if the temperature is stable.
          Oceane Emmerich Solitaired
