advice on 1300mm 12s twin cat setup... NEED FEEDBACK PLEASE!!!
  • uncle marvin
    • Jul 2022
    • 4
    MHZ 1380mm, running 12s twin elec. TP 5850's 990kv on Swordfish 240's an ready to purchase props an the MHZ drives are 1/4". Are people turning down the shafts to 3/16ths" to be able to have smaller prop choice? most 1/4" props start at 67mm an up, which seems much. advice an info is greatly appreciated.
  • fweasel
    master of some
    • Jul 2016
    • 4286
    you can find ABC props in the 2.1" and larger range, which is 55mm for 1/4 bore. Something like a 2114 might be a place to start.
    Vac-U-Tug Jr (13mph)
    • paulejr
      • Mar 2023
      • 165
      Or , you could cut down a cheaper prop to the size you want, polish, balance, sharpen and maybe even try cupping and cutting the trailing edge by the hub. You can, kind of experiment on a cheaper alum prop to see what you can learn. Just a thought. Kinda like this : VXP BV642/2 42mm 1.6p 4.76mm B Cup Non Lift CNC Alloy Prop Boat Propeller MOD 3792769818350 |
      • Bande1
        • Mar 2023
        • 680
        drill out a 3/16 prop to 1/4
        • uncle marvin
          • Jul 2022
          • 4
          come to the same conclusion...... all summer try an try again. but i will know next summer.
          • vvviivvv
            • May 2009
            • 1079
            Speak to chris hoffman, i know he did have some X470 R blanks, get one of them cut down to 57mm
            it's a hot setup so im assuming you want to go fast, later on experiment with some Abc props the 2115-17-45 is a nice prop on twins
            Uk SAW record holder
            • paulejr
              • Mar 2023
              • 165
              redrilling... huh, one needs a pretty good precision setup to insure it gets drilled properly, straight and square ...if you are off by more that a few thousands of an inch either way, the wabble will tear your boat apart (or drive line) before you can say fast electric.
              • Bande1
                • Mar 2023
                • 680
                not really hard to drill square with a decent drill press. then you're only drilling 5-7mm. then you will balance it afterward. Id be more worried about not leaving enough material on the prop hub.
                • fweasel
                  master of some
                  • Jul 2016
                  • 4286
                  Square doesn't mean concentric too. New hole could be dead nuts on square and might never balance out. Safer and more reliable to just buy the right prop for the setup to begin with.
                  • Bande1
                    • Mar 2023
                    • 680
                    he cant buy the right prop, that's the point here. sometimes you have to adapt and overcome.
                    • Peter A
                      • Sep 2012
                      • 1486
                      Perhaps the op is best to either get another set of drive shafts already turned to 3/16", or get his existing ones machined down to suit.
                      • paulejr
                        • Mar 2023
                        • 165
                        well, he asked for suggestions , not stepping all over each other trying to be the only one right.
                        • uncle marvin
                          • Jul 2022
                          • 4
                          I got up with Mr Hoffman, an he sent out 2 sets to get me started. Any feedback is still great. Thanks to all.
                          • fweasel
                            master of some
                            • Jul 2016
                            • 4286
                            Chis is a good place to start. What sizes did you order?
                            • dasboata
                              • Dec 2010
                              • 3152
                              very hard to drill out a prop, tell me how you chuck it in a drill press ,, Iv try a few time , on a lathe and it's near impossible to do it square
