Basic prop info
  • chuck de
    • Nov 2021
    • 4
    Basic prop info
    What do ya'll recommend for a newbie to read about prop selection the dos and don'ts. I have a helion rivos bl 1800kv 30amp esc 3s 4000mah 25c all stock to the boat. I bought the boat used and have never run it. The prop was broke I have ordered a graupner k series 40 mm and 42 mm . I have read tips & info here just looking for more info.
  • LibertyMKiii
    • Dec 2018
    • 127
    I think the big do's and dont's list is fairly short.
    Don't - modify a copper beryllium prop without good PPE and ventilation.
    Don't - put too big of a prop on it.
    Don't - Run a new prop and assume its fine using the whole battery. Run it for a few passes back n forth and then check everything with an IR gun.
    I have found the most efficient prop for my mono hull / deep Vee is the Octura X Seires. I don't know a lot about sizing for a boat that size as all of my boats are 40+"
    It had seemed like taking my boats hull size in inches and making that transition to prop in MM +3mm worked well so far for electric setups. So for example 42" mono runs great with a 45mm prop. (Octura X445 or X645)
    I may be wrong but if your boat is only 24.5" then maybe a 27-32mm prop is best? Hopefully some experience with smaller boats can chime in to assist there, but that 40 and 42mm prop sounds very large for a small boat with a 40a ESC.
    • Johnc
      • Aug 2015
      • 199
      Ramp up:
      Replace the ESC to a 120/180amp (with a 1800kv motor for sure)
      Batteries: should be at least at min 5000mah/50c or better for decent run times (3-4 min)
      As far as props, check out and look up "dashbota" on this site and get some good props. Props on FE boats run at extreme rpm's and need to be balanced/sharpened (if not bad things can happen)
        • 7673
        I just looked up the Helion and found an example on A-Mains site. Can?t find a factory prop size tho. 3s and 1800kv is keeping a pretty low RPM (I normally would run 5-6s on this kv) which would allow use of a bigger prop and better runtime. Also a lower amperage ESC. Based on this info I think you are not too far off the mark on this.
        Now if you get bored of it (as we all seem to) we can revisit this as an upgrade
