I'm looking for some help understanding data from some prop testing. First, I am running a Leopard 4082 1250KV/2.5Y motor with water jacket. I have the OSE 150A ESC and running 2 identical and quite new [7 charge/dis-charge cycles so far] 3-cell RoaringTop LiPo batteries (55C 6500mAh 3S2P) to get 6S for the boat. Details on the boat and the full prop testing chart can be found at this thread on the forum: Joysway Invincible Razor 37 inch mono assembly
I tested all except one prop on the same day and same battery packs. I did not have a GPS for speed but I was mostly looking at AMP draw and temps for these tests. For all tests, everything stayed cool. Air temp was 52F, water temp was about 45F. Wind speed was steady at 10mph out of the south and the long part of the pond runs north-south so each run was 3 or 4 "round-trips" in order to even out the impact of the wind and waves. The Graupner 51mm prop was tested on a different day with the wind essentially the same but air temp was only 40F. I had tested a few other props but they were smaller diameter and the results I got were as expected. These the the ones I'm not sure about:
The first surprise to me was that the Graupner plastic 48mm dia. and 51mm dia. props were nearly identical in data output. I expected the larger prop to have a higher Amp draw. Is anyone else surprised?
The other surprise was how high the Amp draw was with a metal de-tongued 48mm dia. prop. Total pitch isn't that much different than the 51mm prop but the Amp draw was, in my opinion, significant. I realize the pitch ratio is higher but being de-tongued, I thought that helped, especially to allow higher RPMs. But in this case, the RPM max was lower. Any ideas?
I have run it a few times now using the Graupner 48mm and did record a top speed of 39mph so far, but that was also in windy, wavy conditions. I want to get a good metal prop (CNC or Octura) for durability, but don't want to keep spending money on props if I don't have to.
Thank for the assistance!
- CNC 4816-D (de-tongued) is 1.6x48=77mm pitch. Ran 30 sec. Max Amp Draw=130.1. Max Watts=2,705. Max RPM=23,100
- Graupner K2317.48 is 1.4x48=67mm pitch. Ran 35 sec. Max Amp Draw=108.2. Max Watts=2,229. Max RPM=25,380
- Graupner K2317.51 is 1.4x51=71mm pitch. Ran 2 min. Max Amp Draw=108.5. Max Watts=2,225. Max RPM=25,320
