OK guys I will add stuff to this post as we go along, I'm ignoring any questions of what prop do I need on my set up,, For argument sake All model boat props were 2 blades in the 80's so when you wanted a 2 blade prop you asked for a 440-450-460-470- ect,,, now when the 3 blades came out or got discovered back then they became 440/3-450/3-460/3-470/3 ect,lets all get on the same page
Propeller talk post
17 is the diameter 15 is the pitch angle. if you multiply 17 times 15 it equals 2.55” of total pitch. For every turn the boat travels 2.55”. There is slip. Can’t be much simpler.
Sent from my iPhone using TapatalkComment
The problem is how to ask for the exact ABC prop you want.
diameter - pitch ratio - rake - blade area - number of blades - chopper/cleaver - left or right hand
Use the maker’s prop designation. Can’t be any simpler - if you want to identify a specific ABC prop.
Vac-U-Tug Jr (13mph)Comment
common sense says yes,, tighter thrust cone more thrust , I don't think the turns matter if your using a strong enough servoComment
