Proboat Prop problem
  • Kenny Joz
    • Mar 2019
    • 2
    Hello all this is my first post and I have a question about props for my Proboat Veles. The manual states that the box stock prop is recommended for up too 4s and if using 6s constantly to use factory replacement part # PRB282027 which is a misprint it's actually #PBR282028. So my question is has anyone run into the problem of the hub on the replacement being too short too allow tightening down of the prop...? I attached pictures of Box stock and Factory replacement.
    Thanks in advance. Ken
    Welcome aboard. I don’t have a Veles but this condition is not uncommon. You need a soacer between the prop and the nut. You can make one from a piece of brass tubing, or by some here:
    https://www.offshoreelectrics.com/proddetail.php?prod=ose-83280
    • Kenny Joz
      • Mar 2019
      • 2
      Thanks, I was thinking about machining a spacer but wasn't sure if it would have any ill affect on the prop shaft or the strut bushing. I will just order a couple from here.
      • Alfa Spirit
        • 2131
        Did you try a spring ?
        LoL
        • dasboata
          • Dec 2010
          • 3152
          we used to use fuel tubing in the old days
          • photohoward1
            • 1611
            And still do.
            • dasboata
              • Dec 2010
              • 3152
              Originally posted by photohoward1
              And still do.
              right on !!!
              • Capt'n Crash
                • Mar 2015
                • 166
                Is it not possible to just loosen the drive dog and move it further back?
                • Alfa Spirit
                  • 2131
                  You can' t move the DD each time you change the propeller. The lenght of the flexshaft is not adjustable
                  • Capt'n Crash
                    • Mar 2015
                    • 166
                    If that's the case then I would email Proboat customer service and see if they have a better solution to the problem.
                    • TRUCKPULL
                      • 2975
                      [ATTACH=CONFIG]164894[/ATTACH][ATTACH=CONFIG]164895[/ATTACH]
                      The prop in the second picture has got a shorter hub then the prop in the first picture.
                      Those two props are not the same length.
                      Larry
