P-Hydro prop recommandation
  • Maxime20p
    • Jun 2018
    • 4
    Hi,
    I have a new boat this year with the following setup
    Phydro, 4074 motor 2200kv, esc 180 amp. 2x 4s 4300mah in parallel.
    What prop would you recommand? I bought a x440/3 and a 442. Would you go with something else?
    I added a pic of my boat to give an idea of the hull.
  • CraigP
    • May 2017
    • 1464
    Seems like you can go bigger than that. At least an M445 or ABC 1816-17 on there. You have enough battery to get you through a heat. Looks like a great boat, enjoy that!
    • ray schrauwen
      • 9438
      If you can’t get an abc as suggested above, a Proboat Veles or ul-19 stock prop is not a bad start either. Great hobbies sells them.
      • Maxime20p
        • Jun 2018
        • 4
        You dont think its gonna overheat with a 445?
        • rol243
          • Apr 2017
          • 1038
          Try the 442 firstly with 6 laps and test all temps .The 445 should be ok with your motor size and esc size. give the boat 4 fast laps and test all temps before trying 6 fast laps. also you might want a mojo racing turn fin .
          • boredom.is.me
            • Jun 2009
            • 595
            My Pickle ran a cnc m642 and always came back stone cold. The only reason for not propping up was for open water stability and I never gave it a turn fin. I'm going to try the UL-19 prop next as there really is no ABC option available from OSE.
            I forgot to mention that it is also running a 2200kv 3660 on 4s.
            • Maxime20p
              • Jun 2018
              • 4
              I also ordered cnc 442/3; cnc 444; octura m445 and m545. Gonna have some testing to do ��
              • rol243
                • Apr 2017
                • 1038
                If the hull needs a better turn fin try the mojo racing turn fin, very good.
                • Maxime20p
                  • Jun 2018
                  • 4
                  I prefer straight fin. I like to run as scale as possible.
