Suggested prop size for an Osprey
  • Old School
    • Aug 2017
    • 686
    I am currently building a 41" Hobbyking Osprey mono and will need to decide on a suitable propellor to commence running (testing). By default the hull is fitted with a Turnigy T20 (56/98?) which will be set at 1280kv on 6s with two 6s 60C batteries in parallel. This will couple to a 3/16" drive shaft through a Speedmaster 1/4" stinger modified to run a 3/16" cable. The ESC will most likely be a Hifei Swordfish 200/220 amp model.
    I currently have the following propellors to consider (balanced and sharpened) -
    46.5mm 1.4 2 blade (brass)
    48mm 1.4 2 blade (brass)
    52mm 1.4 2 blade (brass)
    52mm 1.4 3 blade (stainless)
  • jim82
    • Jan 2013
    • 1358
    Try both the 52mm props you have should get you in the low 50's
    • jim82
      • Jan 2013
      • 1358
      • Old School
        • Aug 2017
        • 686
        Many thanks
