prop and motor setup
  • dasboata
    • Dec 2010
    • 3152
    #31
    I like and prefer 3 blades on a mono you will find they tend to handle better with better accelartion
      • 7673
      #32
      Originally posted by rad35
      another question is there an advantage to running 3 blade prop vs 2 and lift vs no low lift (x vs m) style. for my app.
      Sizing and amp draw are your concerns here, for starters the CR 447's are good. Easy to sale off if you move past them. Especially if you get Chris to detounge and sharpen/balance them.
      You will be able to easily move up to 10s too at a later date with that Kv
        • 7673
        #33
        Oh yknow I just had a look at the pic of the back of the boat, how far up the transom off the running surface of the boat would you say the stinger prop shaft centreline is.
        I would hate to recommend a prop and have it not touch the water.
        • rad35
          • Oct 2016
          • 83
          #34
          I would start with a smaller size and then go up depending on heat from the very bottom of the v it's 1 in. from below the stingers it's 1/2 in.
            • 7673
            #35
            Well 1/2" should work for 447's. You may need to lower them. Did this boat run before?
            I just re read, it was not run before.
            • rad35
              • Oct 2016
              • 83
              #36
              I will start with that who is chris? on sharpening props. is my other option to go to bigger motors to run bigger props or not an option. the stuffing tubes are right on the bottom of the hull where they enter the back now sothe only way i can lower them is stinger angle i have 1/4 in. flex cables.
              • fweasel
                master of some
                • Jul 2016
                • 4291
                #37
                Dasboata
                Vac-U-Tug Jr (13mph)
                • dasboata
                  • Dec 2010
                  • 3152
                  #38
                  LOL That's me the prop guy!
                    • 7673
                    #39
                    There is 'the man'.
                    • rad35
                      • Oct 2016
                      • 83
                      #40
                      chris how do i get in touch with you about doing props? So i go with 447 props 3 blade like chris suggested ( L & R ) tp 4060 1050 5y kv 8's 240 amp esc's. should be a good starting point?
                      it's been a process but i think we have it. Thank's everyone for the help and bearing with me on this. my next hull will be nothing installed when i get it LOL.
                      • dasboata
                        • Dec 2010
                        • 3152
                        #41
                        Octura has not made the 447/3 in a few years,,, you can not get them, I do have some prop shop sets of 4714/3 in ss,, that are just about the same size, or can go up to 450/3 octuras and cut them or reduce them down a bit ,,you can touch base with me threw PMs or email me at dasboata@aol.com thanks Chris
                          • 7673
                          #42
                          That should be a solid setup rad35. PropShops are good(I have a set) but you can just go Octura two blades as well. A three blade does draw more amps due to the extra blade. My preference and I'm sure Chris will agree is three blades on a single as it seems to even out the thrust.
                          • dasboata
                            • Dec 2010
                            • 3152
                            #43
                            Defiantly on a mono !!!!
                              • 7673
                              #44
                              Oops, forgot that part, haha. Thanks Chris
                              • rad35
                                • Oct 2016
                                • 83
                                #45
                                thank's again guy's for all the help. now just need to figure out esc size will it hurt to go bigger like 220 or 240?
