Blackjack 29 V3
  • dtacmed
    • Mar 2008
    • 199
    Blackjack 29 V3
    What would you recommend for a stock setup on 4s to upgrade to a little better prop ? Thanks !
  • jim82
    • Jan 2013
    • 1358
    How are you temps at the moment? I think those props are ss just need s/b! then go from there.
    • jim82
      • Jan 2013
      • 1358
      You will be surprised at how much an S/B prop will do.
      • jim82
        • Jan 2013
        • 1358
        If you do not have the talent what so ever talk to Dasboata!
        • dtacmed
          • Mar 2008
          • 199
          I have sharpened and balanced the stock also have the following x442, x445, x645 and a M445 I guess I'll start with the x442
          • Tails Up
            • May 2016
            • 51
            I like the X440/3 but mine is on 6S. Strut depth is a key factor too.
            • Seanj
              • Jul 2016
              • 4
              I run a prather s220 on my V2 miss geico which is stock with a 60 amp esc, and a 1500 kv motor. I'm running 4s as well. Stock stainless proboat stiletto prop is basically a prather s215 but slightly better cast/cleaned up a bit. It certainly goes quick with the 220 wickedly sharpened, polished, and balanced...
              • fweasel
                master of some
                • Jul 2016
                • 4291
                What did you end up with?
                Vac-U-Tug Jr (13mph)
                • Jesse Flovin
                  jtflovin
                  • Apr 2016
                  • 44
                  I too am curious about my v3, anyone got details on prop recommendations. 4s or 6s , diameter, pitch, brand, temps!
                  • fweasel
                    master of some
                    • Jul 2016
                    • 4291
                    I run 4S with a S&B Octura x642 and just hit 41mph today. Previous best was 38.5mph. I dropped the strut another 2mm this weekend. Motor wire connectors are still pretty hot, 180-190*F, but everything else was 130*F or cooler after a 5min full throttle run.
                    • Fixitguy1
                      • Nov 2016
                      • 45
                      Have been trying to find the prop that you recommended it was a X440/3 B/S what is the brand name and what is it made out of.
                      Thanks,not sure this is the right place for this request
                      • Jesse Flovin
                        jtflovin
                        • Apr 2016
                        • 44
                        I've ran the b220 & x446. The 220 seems to be a great replacement. X446 is a bit to aggressive for stock electronics.
                        • fweasel
                          master of some
                          • Jul 2016
                          • 4291
                          The prop is made by Octura. The model is an x440/3, which means x series, 1.4 total pitch, 40mm diameter, 3 blade. B/S was an abbreviation for balanced and sharpened. It's sold in a raw, unfinished version as well. It's made from copper beryllium. You can buy it from OSE prepped and ready to race here: http://www.offshoreelectrics.com/pro...B-oct-x440%2F3
